It is currently Tue Oct 27, 2026 12:50 pm
 Post subject: Corrosion Control
PostPosted: Sat Aug 19, 2017 12:28 pm
I've got my instrument panel out for ADSB update. Found some corrosion on dash and other basic fuselage parts . Question is: ACF-50 or Corrosionx?
 Post subject: Re: Corrosion Control
PostPosted: Sun Aug 20, 2017 7:10 am
Corrosion X is thicker viscosity that stays in place longer. ACF - 50 is much thinner viscosity and creeps more into lap seems but does not last as long, if you use it as recommended you may find it coming out of seems / joints for a while.
Phil
118BC
PostPosted: Sun Aug 20, 2017 11:29 am
I like stuff getting into my cracks and crevices ! ??? I would prefer corrosion treatment to get between the sheets as much as possible . ::) It's the stuff you can't see that leads to bigger problems .
PostPosted: Fri Aug 25, 2017 9:43 pm
August Sport Aviation has a good article on corrosion control and what to apply . ::)
Users browsing this forum: No registered users and 49 guests
[ Time : 0.228s | 13 Queries | GZIP : On ]
