Hello All.  I am rebuilding a project that was originally begun by my father.  Due to some workmanship that I was unsatisfied with, I have re-skinned the outer wing panels, re-skinned the horizontal tail, built a new rudder and ailerons, and re-skinned the deck under the canopy.  I have now turned my attention to the center wing section.  It has the extra rivets in the nose ribs, but does not have the extra row of rivets in the spar, nor the vertical stiffeners on the spar web.  Also, it also uses .025 thick material for the skin.  For these reasons I plan to re-skin it so that I can add the mods and use .032 material.  I noted the post in "suppliers" that Richard Ecklund does not support the T-18 anymore.  I did attempt an email to
thorpt18@jps.net, and sure enough, it could not be delivered.
So, where can I obtain a pair of pre-bent, .032, wing skins WITHOUT holes?  Or do I have to go back to the 1960's and do it with a 2X10 board and lots of muscle?
Thanks for any help.
Bob Hartmaier, Thorp T-18 S/N 573
