flyingfool wrote:
This may be my pure ignorance talking.
But if it is the last 1/4 inch of throttle movement that is causing the over rich condition.  Why not simply change the throttle stop limit to not go that last 1/4 inch?  Or alternatively, change the mixture stops so that it is slightly leaner than in the current full rich position?
Although I understand the thought process this seems just like a band aid and possibly something that could become dangerous.  I'd rather get to the bottom of the problem (which is most likely jetting)
flyingfool wrote:
Also I have heard of problems with low speed stumbling when that idle circuit passage is plugged.  This while not common issue, but frequent enough issue in Aeronca's that even repeated "overhauls" of the carb by otherwise reputable firms did not find it.  Once sent to a person who knew specifically to look there and clean it out.  The problems went away.  It is worth a try since you said there was some varnish to try to send something through the idle circuit passage.
No slow speed stumbling or other carb issues.  Just a rough condition when the last 1/4" of throttle is advanced.  Worse when the OAT is high.  Fits right in with the rich condition I've diagnosed by leaning the mixture at full throttle run up.
flyingfool wrote:
Also there was some problems with the float needles and whether they were metal, plastic (neoprene) or derlin.
I examined them and although I can't see part numbers they are both brass and the needle has no damage or wear on it's tip coating.
flyingfool wrote:
A final thing would be to check the float level with a proper "head" pressure of fuel.  Some floats were plastic or two piece and were changed over time.  However the buoyancy of a metal versus a plastic float are different resulting in the fuel level in the carb bowl to change.  I think some floats had to solder some weight onto them in order to get the proper fuel level in the carb.  Also a small amount of fuel if the float leaks could also affect this.  So again give that a real check.
I checked the brass floats with a magnifying glass for any dents or leaks.  Submersed in fuel there were no leaks and nothing inside the float after taking it out.  I didn't check float height when installed.  Once I had it back on I wanted to test it.  I can easily add an adapter and clear tubing to check although I don't think that is the solution.  From my testing it appears 100% that it's too large of a main jet (whatever they call that on these carbs) since that is the only thing operating during the last 1/4" of throttle.  Since I have no numbers on those I don't think it is wise for me to start pulling jets and testing.  It could also be an issue with airbox.  Since it's a car airbox there might be more restriction.  If I re-design and put a better flowing airbox that could easily give more air and balance out the fuel issue.  If not then I'm only out my time of building a new airbox.
I'm curious why aviation hasn't adopted the use of wideband o2 sensors in the exhaust for mixture control.  Seems there are tons of sensors and ways to get the "proper" lean although the most simple thing is just monitor the mixture.  I'm thinking of putting my dual handheld wideband system in the exhaust and monitor it to confirm all my other testing.
I think Bill has it right on the money.  The enrichment valve.  So far I've just been keeping it pulled back slightly and it works fine.  I would rather not restrict the travel of the throttle though.
