It is currently Wed Oct 29, 2025 5:36 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sun Mar 20, 2016 9:32 am
New top cowl installed. I modified the design a bit. I was inspired by a J3. mIght be a bit draggy but it should cool well.
PostPosted: Sun Mar 20, 2016 11:26 am
Dick : I assume you found a dust boot for your master cylinder ? I still have only one that I posted earlier . If someone else wants it sing up or it goes in the swap meet box ! :o
PostPosted: Sun Mar 20, 2016 1:35 pm
Looks like a big mouth bass! :o
PostPosted: Sun Mar 20, 2016 2:03 pm
Dick,
Seriously, make sure it is tied down prior engine start. CG is way forward without the wings on. Yes, I saw the fire extinguisher.
PostPosted: Sun Mar 20, 2016 3:21 pm
Bob makes a very good point . Tie me wallaby down sport ! ??? Chocks can't be big enough and don't forget to hold full back stick during the entire start/engine run sequence . :o
PostPosted: Sun Mar 20, 2016 4:59 pm
I weighed the tail and it came in over 50 lb. before I got in. as per good TD technique, I did hold the stick back the whole time.
Almost everything works like it's supposed to, except the oil pressure reading... will work that out with MGL. Cyl 4 has given me trouble since I got the airplane... had plug fouling back then. I put new BY plugs in. Today it's oily plugs and a dead cylinder, intermittently. EGT was up on that cylinder, but it went dead for a bit. Probably a stuck valve, but I'm not going to judge until all the facts are in. For now I'll chalk it up to a long period not running.
The scoops definitely kept the cylinders cool.
We're getting there.
PostPosted: Sun Apr 17, 2016 6:51 am
I abandoned the metal cowl top piece. It wouldn't have matched the glass cheeks without forming. We decided not to buy a new top piece for the same reason..... there was a good chance it wouldn't fit either. SO, I made one.
It was a lot of work, and I learned a lot. (meaning that it didn't go smoothly :) )
DW
PostPosted: Sun Apr 17, 2016 12:12 pm
That looks very good, Dick!
PostPosted: Sun Apr 17, 2016 2:52 pm
You win the fiberglass award by sticking to it . No pun intended . ??? Looking good Billy Ray !! :o
PostPosted: Sun Apr 17, 2016 8:34 pm
It looks even better on the airplane.
lance38dt
PostPosted: Mon Apr 18, 2016 9:09 am
Dick I know you have a lot more pics, let's share.
Lance
PostPosted: Mon Apr 18, 2016 5:00 pm
I would like to hear the audio of Dick using certain 4 letter words as he tries to maneuver the sticky stuff into a useful shape !! YIPPEE KI YO KI YAY !! ::)
PostPosted: Thu May 12, 2016 8:18 pm
Baggage Compartment taking shape.
Back wall, gluing on the fabric.
Behind the back wall, about to glue in the wooden spacers to get around the flanges on the bulkhead.
Back wall in place, with floor. Just used trunk liner from a surplus store over thin plywood.
Aft tunnel, trim piece, and center tunnel, all painted.
PostPosted: Thu May 12, 2016 8:40 pm
Decided to go for an inspection panel now instead of later.
Primed. Yeah, I went overboard with the number of screws.
Installed. Just need to fix up the paint.
PostPosted: Thu May 12, 2016 9:43 pm
You could make a pretty good living in TJ doing "Tuck n Roll" for one of the local auto upholstery shops ! ???
Users browsing this forum: Bing [Bot] and 14 guests
[ Time : 0.351s | 14 Queries | GZIP : On ]
