It is currently Sat Nov 08, 2025 5:53 am
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
 Post subject: Re: Tail wheel skipping
PostPosted: Mon Feb 22, 2016 10:13 am
Might also check the 4130 brackets on the inside of the tail. They can crack. They were originally .063, and were later changed to .090.
PostPosted: Mon Feb 22, 2016 1:55 pm
Cubes read my feeble mind ! :P I would look for a loose broken bolt . Cracked bracket or a lair of loose rivets . ???
lance38dt
PostPosted: Mon Feb 22, 2016 4:09 pm
I'll be looking, thanks for the input.
Lance
PostPosted: Tue Feb 23, 2016 3:19 pm
This is a little off the subject, but I picked up a used tail wheel at the fly market as OSH. The tail spring was broken off in the socket and when I tried to remove it, I discovered they had drilled the hole for the bolt off center far enough that i believe that's why the spring broke. Just a note of caution for when you're drilling the tail wheel spring.
[ Time : 0.090s | 10 Queries | GZIP : On ]
