It is currently Sun Sep 14, 2025 10:08 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Feb 07, 2016 5:16 pm
Took my gear off again yesterday to make the repair. Got it back this afternoon. tHe patches aren't quite placed the way James Ball did it, but close enough.
PostPosted: Tue Feb 09, 2016 4:11 pm
Another picture.
PostPosted: Wed Feb 10, 2016 5:47 am
Wait and see,but my guess it will still crack at the crotch
PostPosted: Fri Feb 12, 2016 7:26 am
I'm more optimistic, Bill.
The way I see it is that the original weld design could have been better. The cracks initiate at the inboard end of the weld bead... a spot where the bead is spanning a relatively large gap between the round gear leg and the thin flat reinforcing plate. As has already been discussed, the bead is also across the line of stress. One a crack initiates, it will propagate easily.
This patch design does three things:
1 It rounds out the inside corner, which is much more resistant to fatigue.
2 It adds a lot of material section to the problem area, which lowers stress, which is also better for fatigue.
3 It turns the transverse weld into a longitudinal weld, which is a better way to weld something under stress.
Personally, I think if the reinforcement plate design had originally incorporated a shape like this, we wouldn't see gear cracks in the fleet.
Time will tell.
PostPosted: Fri Feb 12, 2016 11:04 am
Dick,
You need to make sure that surface is flat enough to handle the accompanying hardware. Side loaded bolts in that area would not be a good idea.
PostPosted: Tue Feb 23, 2016 6:30 am
Not a factor, Jim.
PostPosted: Wed Jun 01, 2016 10:00 pm
I understand the doubler plate on the front, this area is under tension when landing etc.
I don't understand the need for the plate on the back, this area is under compression and does not have a history of cracking?
PostPosted: Thu Jun 02, 2016 5:14 am
Yeah, I thought the same thing, but trust me, they crack on the back too. It'd just a poor weld design.
In theory, theory and practice are the same, but in practice they're not.
DW
[ Time : 0.107s | 10 Queries | GZIP : On ]
