It is currently Sat Nov 01, 2025 1:04 am
Jon Linke
 Post subject: Aileron hinge
PostPosted: Wed Jan 19, 2011 7:50 pm
Is there any operational experience with a full span aileron hinge? Is rear spar bending a concern for a full span hinge, creating a possible bind?
Thanks, Jon Linke #1321
PostPosted: Wed Jan 19, 2011 9:52 pm
Reason for installing a full span hinge ? Makes gettin that hinge pin in a bit of a talley wack ! Plus the extra weight.
mac nussey
PostPosted: Thu Jan 20, 2011 6:29 am
There is a reference somewhere back in a NL or the forum re: a binding problem. If I can find it I'll post it.
Mac Nussey
PostPosted: Thu Jan 20, 2011 8:48 am
Mac is right. I had this conversation with my dad years ago (aspiring young engineer's curiosity). Dad never discouraged that when it came to the airplane and mailed off a letter to John Thorp. The response was that a full span piano hinge was a no no in his book due to the potential for binding.
PostPosted: Thu Jan 20, 2011 2:21 pm
As a wee lad I to remember such discussions & I think someone had actually built a plane that way. They quickly found aileron stick forces extremely high.
I came across this subject a while back, not sure exactly where. May have been a very early NL or post ?
PostPosted: Fri Jan 21, 2011 8:04 pm
Lu Sunderland Quote from NL 03/06/1972
"The full-length aileron hinge makes a good seal, but is not a
good idea because of the potential for high binding friction.
When I added two segments to the S-18 aileron hinge because
of reported wear in T-18 hinges, John Thorp was upset. He
said that he had gone to great pains to reduce the aileron
control friction to a minimum and hated to see anyone put
friction in the system unnecessarily. Since it is impossible
to get perfect alignment between the mating halves of a piano
hinge, there is inevitable binding in the hinge as it rotates
and forces the two mating structures to bend by an amount
equal to the misalignment."
admin
PostPosted: Fri Jan 21, 2011 8:05 pm
I got a full span piano hinge 360 hours. its not binding at all.. J.P
*** admin posted for James Peran ***
Forum Administrator
admin
PostPosted: Fri Jan 21, 2011 9:10 pm
Some one forget to tell the people who design the Hercules aircraft...
BTW.they replacing the pins after 500 hours. J.P
*** admin posted for Jame Peran ***
Forum Administrator
[ Time : 0.234s | 10 Queries | GZIP : On ]
