It is currently Sun Nov 02, 2025 5:32 pm
 Post subject: Champion Spark plugs
PostPosted: Sun Dec 27, 2015 11:02 am
Am I the only one who was not aware of the Champion Plug troubles ? was reading an article on it yesterday. This has been going on since 2008, I guess I should do my homework a little better..Dan
 Post subject: Re: Champion Spark plugs
PostPosted: Sun Dec 27, 2015 12:14 pm
Naw, you aren't alone Dan... it hasn't been too long since I learned about it too. I have a spark plug cleaner, and had a couple of sets of Champions. I tested them all with an ohmmeter and found a few with high resistance. Even though my engine seemed to run just fine with them, I tossed the "bad" ones.
PostPosted: Sun Dec 27, 2015 6:33 pm
I bought a new set of Champions at Sun n Fun 2015 and by the time I landed at Oshkosh 2015 my motor was running on about 5 plugs. Ohm them out and the resistance was infinity on several. Went over to Spruce and bought 8 Tempest. Fixed the problem.
Tempest web site has some good information on plugs. Champion plugs have a screw in the top that you can unscrew and remove the resistor, I thing this set up allows moisture in the plug and ruins them. Tempest is a sealed unit. The higher the resistance the higher probability that the plug will not have a strong spark but smolter and create cylinder problems down the road.
PostPosted: Sun Dec 27, 2015 6:46 pm
Dagburnit Bill, thought I made a discovery, John I'm going t go with a Tempest plugs as mine are a bit old. They do have the screw in the Barrel that holds the Capacitor spring. I think Champion has corrected their troubles but it did take some years to get it done, Igot in a lot of interesting reading on the Infamous Spark maker this weekend. Dan
PostPosted: Sun Dec 27, 2015 7:40 pm
Dan,
I seem to remember hearing about Champion plugs but since my motor has Unision aka Tempest plugs I didn't worry about it and promptly forgot it.
PostPosted: Mon Dec 28, 2015 9:01 am
Dan - you'll recall I arrived with a rough runner at Tony's with 3 crappy REM40s (they came (in new packaging) with a new set of slicks I purchased 200 hour ago) - Tony gave me a few older but sparky loaners to get home on - threw some new Unisom 37BYs in when back home - running much smoother and about 4MPH faster on the new plugs.
PostPosted: Mon Dec 28, 2015 8:10 pm
That story sounds like a bunch of other stories I've read about in the past 3-5 days of research Frase, I am hot after a handful of em........mine have 300 hrs on em I had
A little roughness going home from Rosamond, and starting isn't happening on the first blade like it usually does. I'm due for inspection next month, I will re plug all fire holes and service the spark makers...........Dan
PostPosted: Mon Dec 28, 2015 10:12 pm
I was able to snatch up 12 UREM37BY plugs (new) on e-bay for about $10.00 each . ::) BOOM !
PostPosted: Tue Dec 29, 2015 8:02 am
Good show Rich!! let me know if you want to unload the extra 4, you and Dean are masters at finding the deals thats for sure!! Dan
PostPosted: Tue Dec 29, 2015 9:48 pm
Dan : The "extra" four plugs already have a home . ??? (2) are under the seat along with my tool kit/spare parts . The other (2) are sleeping with the other (8) hoping for an immaculate conception for (6) more plugs ! ;)
PostPosted: Fri Jan 08, 2016 1:58 pm
So if a guy is in the market for a set of REM37BY, would he get new Champion plugs from A/S or Tempest?
Les,
Albuquerque
PostPosted: Fri Jan 08, 2016 2:14 pm
Les : The REM37BY is a Champion spark plug number . UREM37BY is the Tempest/Unison Plug number . Yes , Spruce has the UREM37BY plug . Pretty sure most other major aviation part sites have them also .
PostPosted: Fri Jan 08, 2016 2:20 pm
Right, so is Tempest the one to buy?
PostPosted: Fri Jan 08, 2016 3:59 pm
Si'...The Tempest UREM37BY ( formerly Unison-Autolite) is the one to get . I should clarify this msg a bit , I use the UREM37BY in my 0-360 . Not sure if it is the correct plug number for other lycomings ?
Sparky
PostPosted: Fri Jan 08, 2016 6:17 pm
For plugs check Lycoming document SI 1042Y
[ Time : 0.177s | 10 Queries | GZIP : On ]
