It is currently Fri Oct 31, 2025 7:44 am
Post new topic Reply to topic  [ 86 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: 66WT coming back
PostPosted: Tue Aug 11, 2015 6:15 pm
Terry : Amazing what a lot of money and patience will do ! Sedona will be here before we know it ! ;D
PostPosted: Wed Aug 12, 2015 7:51 am
In this process I checked the entire airframe. The 2 specific items I made assumptions on were issues on the first flight. I checked and ran both the aileron and elevator trim motors. They moved the jackscrews so I didn't investigate further. That "assumption" was the cause for only 2 flights to be done. I pulled the aileron trim motor off first. Faintly you could read the make,model, and at the bottom...24V. The exact same motor was used in the elevator trim. IT's no wonder why the trim would move on the ground, but not under load. I've replaced the elevator trim with the Dayton 2L009 and I have a 12v geared motor coming for the aileron trim section. It will be ready to fly again shortly.
PostPosted: Sat Sep 19, 2015 7:44 am
This will be the final post as WT is no longer a "project". She will fly again this am and officially be returned to service. This one has been quite the challenge. I look forward to 218TH going together much more smoothly.
PostPosted: Sat Sep 19, 2015 8:19 am
an exciting day ahead i'm sure. Good for you.
PostPosted: Sat Sep 19, 2015 8:55 am
Nicely done. That was a lot of work. Tell us how she flies.
PostPosted: Sat Sep 19, 2015 7:43 pm
PostPosted: Sat Sep 19, 2015 8:20 pm
Well done!
PostPosted: Sat Sep 19, 2015 8:27 pm
Looks like a winner ! 8)
PostPosted: Sat Sep 19, 2015 8:41 pm
Congratulations! Now the fun begins
PostPosted: Sat Sep 19, 2015 8:48 pm
Thanks guys, But the plan since day one has been to finish WT- put it on the market, sell it in order to complete what will be N218TH.
I'll get the wheel pants on WT next week and get some time on it. Shortly, I'll list it on Barnstormers and see what happens.
PostPosted: Fri May 27, 2016 8:47 pm
Spent some time flying WT around Destin this afternoon
[ Time : 0.104s | 10 Queries | GZIP : On ]
