It is currently Wed Oct 29, 2025 7:21 pm
 Post subject: Milspecproducts
PostPosted: Tue Apr 21, 2015 3:49 pm
This is for Gary Jacobsen . Gary this is the outfit I used for my fasteners . SS 4000 series studs and grommets , adjustable aluminum receptacle . http://www.milspecproducts.com
Scott Stine
 Post subject: Re: Milspecproducts
PostPosted: Fri Apr 24, 2015 8:20 am
Images: 5
I used the same fastners on my cowling....very convenient and exactly adjustable.....all with the same sized studs. Only problem is that they are expensive.....but in my opinion very worth the cost.
PostPosted: Fri Apr 24, 2015 8:32 am
Everything in aviation is expensive except the air ! ???
PostPosted: Fri Apr 24, 2015 8:04 pm
If you don't mess them up, you only have to buy them once.
PostPosted: Fri Apr 24, 2015 11:06 pm
Unless your aircraft has steel fasteners and after 45 years they have corroded and won't hold paint.
[ Time : 0.122s | 10 Queries | GZIP : On ]
