It is currently Thu Oct 30, 2025 2:56 am
 Post subject: Compression test
PostPosted: Mon Feb 17, 2014 12:18 am
Does the engine need to be run to normal op temp to do a diff. compression test ? EAA site indicates it is not required as I viewed the video . Other links say a "warm" engine/rings is best ? ???
 Post subject: Re: Compression test
PostPosted: Mon Feb 17, 2014 12:34 am
You can do it either way... you may find that everything seals up a little better, with warm parts at the proper clearances & a fresh coat of oil on everything if you do it after a run, with a warm engine. You'll probably get a little better/higher reading that way. I think that the most important thing is to do it the same way each time, so that you're comparing apples to apples.
PostPosted: Mon Feb 17, 2014 7:20 am
I agree with John. I do mine cold as it reduces the tendency to drop a spark plug (hot!) when done warm. If a cylinder comes up short, I will run the engine and try again. Remember, a compression test is only a screening test; not decisive. Several articles by Mike Busch in Sport Aviation have addressed the meanings of the results of compression tests.
Lastly, NEVER try to do a compression test alone. We have a fellow on the field who nearly bled to death when he was struck in the shoulder by a blade as he tried to check a C-150 alone. He has limited use of that arm to this day.
PostPosted: Mon Feb 17, 2014 4:01 pm
Good points from Bob - I check comps at conditional only by and large. I checked at oil change once just to get a comparison. When I change oil, I always fly the plane to get the oil viscosity as low as possible before draining it, and after I check mags off and can see the keys on my dashboard, I pull the prop through (as though it were hot) while the oil is draining - you can tell if there is an abnormally low compression in a cylinder that might need an additional check.
Since I always check and rotate my plugs at oil change, I handle them hot. A piece of carpet under the drop zone is a smart move. In case anyone is not aware, dropping a heavy REM 38/40 plug on a concrete floor pretty much assures a cracked ceramic resistor.....and hence a now useless plug.
I consider Mike Busch one of the greatest resources of the aviation community, other than Bob of course....
PostPosted: Mon Feb 17, 2014 5:39 pm
All good points guys ! ;) I was either told or read somewhere if you drop a plug on the deck , you might as well throw it away . ??? Carpet might work ?
PostPosted: Mon Feb 17, 2014 9:26 pm
My mechanic tells me you can drop a plug twice but the second time has to be in the trash can.
PostPosted: Mon Feb 17, 2014 11:04 pm
Does he drop the plug or you ? :o If I drop the plug and new one goes in ! 8) How do you know if the mech drops the plug twice ? ??? I guess the old saying still stands true..."Just do the right thing if no one is looking !" ???
[ Time : 0.267s | 11 Queries | GZIP : On ]
