It is currently Fri Oct 23, 2026 5:25 am
Post new topic Reply to topic  [ 252 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 17  Next
Pacer 20
 Post subject: Re: C-FPVE
PostPosted: Sat Dec 14, 2013 2:52 pm
Hi everyone! I working hard on my project during my 2 months OFF on the forum!
I finished my canopy rail and I have to make new support under the rear rail.
Front rail are in place.
Canopy was sliding correctly but some adjustment are required.
When I closed my canopy I want the same effect as my refrigerator door in my kitchen. I dont want to fight with the canopy!
Smooth closing ;)
Thierry
French Canadian T-18
C-FPVE #091
Pacer 20
PostPosted: Sat Dec 14, 2013 3:21 pm
I found all the requested material to build the canopy locking mechanism.
During this time I decided to completed all the resin fairing for the tail section.
I work on the small tail cover. Lot of trimming and adjustment :-\
Tail is 95% done i just need to winish the rudder top cover and all the part is ready for the paint!
Closer look on the easy acces cover.
Thierry
C-FPVE #091
Pacer 20
PostPosted: Sat Dec 14, 2013 3:30 pm
Both wing tips are almost done I have to put a small coat of light putty to complete the parts.
I request a perfect surface. I accept nothing under that. C:-)
Fuel tank was ready to install and I need new tank starp!
New part on her way as per plan!
Installation are good. Now I have to found the rubber to glue between the support and the tank.
Thierry
C-FPVE #091
PostPosted: Sat Dec 14, 2013 4:01 pm
Yeah!!! That's what I'm talkin' about.
Pacer 20
PostPosted: Sat Dec 14, 2013 6:34 pm
Thanks DickwolfF!!!
Post some fresh pictures of your yellow T-18.
My last updates. I have a opportunity to utilise a Big 75 tons hydraulic press to put straight back my bend landing gear.
Look at this monster ??? I have to operate this beast with lot of respect!
The patient is ready for the torture session :o
Gear in position and it's a green light for the first run....
After the 8 times the mission was over. Now I have a new straight leg.
Look at the last trial! See the arc it's impressive :-[
Next week I call the NDT shop for a deep inspection!
To be continu....
Et voila!
Operation total time is 45 minutes! AGAIN.....When you have the good tool it's a piece of cake!
Thierry
C-FPVE #091
Pacer 20
PostPosted: Fri Dec 20, 2013 3:25 pm
Since last week I switch from a part to build to another piece to scratch build!
First is the canopy latch mechanism. Hook is on the way!
I take 30 minutes to do this bushing. A easy part, except for the small radius at the extremity.
This is a hard one :-\ Lot of small cut-out and lot of small bend.
Between that I finish molding my Beacon light. I need to found a old style red lens to install on the top of the fin.
Rudder fairing is done. Lot of sanding..... I'm very happy to build a metal plane!!!! Lancair and Glassair is not for me ;)
Thierry
C-FPVE #091
Pacer 20
PostPosted: Mon Dec 23, 2013 10:03 pm
All the tail section is completed at 99%.....I have to paint all the parts now ;D
I installed the rudder for the last time to adjust the cable and be shure everithing is working correctly!
Rear canopy rail is fit in place so I decide to strip the old paint before the riveting process.
After the clean-up! Original deck are in correct condition. Some very very small aluminium wrinckle or dent but with a light coat of putty this rear part looks almost new ;)
Thierry
C-FPVE #091
PostPosted: Mon Dec 23, 2013 10:16 pm
Thierry: Outstanding work ! A "smooth closing" canopy is a test of patience ! It may ride smooth w/o the glass , but once the glass is attached to the frame it will require more patience and adjustments ! ;) If I had to do over I would probably use self adjusting bearings rather than the plans called for bearings . ??? Good job on the Thorp canopy latch ! I really like mine !
Higher and Faster
Pacer 20
PostPosted: Mon Dec 23, 2013 10:23 pm
Thank for the tips RB! I have the same impression when I fix the canopy on the frame the game was changing....
Thierry
C-FPVE #091
PostPosted: Mon Dec 23, 2013 11:09 pm
The day I finished my Canopy I had to go and get some therapy, seems I had an anger problem and a real bad twitch, couldn't even get around a plastic water bottle without breaking out in a sweat..That canopy bout got the better of me.....Dan
PostPosted: Tue Dec 24, 2013 12:01 am
Dan: Your therapy began the day you started your S-18 ! ??? Now that you are done I recommend "Shock Therapy " once or twice a week ! ;) The "Positive Lead " to your man parts and the "Ground" to your wallet ! :o
All fun aside I got my most useful info for my canopy install from my first Porterville Fly In when I saw your outstanding canopy !
Faster and Higher
Pacer 20
PostPosted: Fri Jan 10, 2014 6:12 pm
Hi!
I take a few minutes to finish welding the support for the canopy handle.
I found on my personnal junkyard the perfect outside handle for the canopy. The dimension is almost the same of the plan. I drill the hole and installed the new shaft. I dont know the origin of this aviation parts but this handle has a new life on a Thorp!
I step back to my center section for a short period of time. I take a look on the plan to cut and bend both rear spar. I always made a small sample to adjust the brake.
Last check and I take the direction of the brake.
Adjustment is correct. I confirm with the scale drawing.
Both spar was cut and I think I drill the hole for the attatchement parts before I bend the parts.
No more time to play I have to pick-up kids at school. Maybe tomorrow I work again on my mistress....
Thierry
C-FPVE #091
PostPosted: Fri Jan 10, 2014 11:30 pm
A smooth closing canopy is a lot of work ! ??? One that does not leak when closed is even more difficult . ::) I managed to do both . Glad I can leave the roll of Saran Wrap at home ! 8)
Pacer 20
PostPosted: Sun Jan 12, 2014 10:05 am
Hey Rich !
During cold winter flight some pilot put grey duck tape around the door to ''seal'' the areas :o
On another way I figure how to install the fuel tank filler..... I dont want to install the access door I want a flush gas cap.
The filler cap is has a flat surface and is just arrived in the curve of the skin.....
Maybe the easy way is to mold a aluminium fairing around the flat cap???
Thierry
C-FPVE #091
PostPosted: Sun Jan 12, 2014 11:04 pm
With my CSA fuel tank the enclosed instructions said to cut off some screws and make a point on the other end . Screw the screw in on the filler neck , put the tank in and place it up against the upper skin . Then take a small mallet and "tap" the top of the skin to make impressions where the screw points are . Worked OK . I also put a thin rubber gasket between the top of the filler neck and the bottom of the top skin to help prevent any Avgas fumes from entering the cockpit . If you use the correct canopy seals and a correctly fitting canopy you will have no leaks ! The other key is a positive locking canopy latch like the Thorp Latch to insure the canopy is completely pulled forward to make the seal . BTW I use two canopy seals . One on the windshield side and a main seal (plans type seal) on the canopy , so when it is closed I have a "double seal" and no leaks ! BOOM ! Shazam !
Looks like you may be able to "grind" down the one edge of the flange to fair with the skin ? ::)
Users browsing this forum: Bing [Bot] and 4 guests
[ Time : 0.256s | 12 Queries | GZIP : On ]
