It is currently Thu Oct 30, 2025 8:22 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: Extended gear?
PostPosted: Tue Dec 03, 2013 9:02 pm
Lou wrote:
Thanks for the feed back guys. One more question, just to keep ya from getting bored.
Assuming the “new standard long gear” the T and the S are the same o same o? (one piece design)
Yes, that's right Lou.
PostPosted: Tue Dec 03, 2013 11:49 pm
Longer gear more prop clearance ! ;) Put a cushion under your bum if you need to see over the nose a bit more with the longer gear ? ??? BUM BOOM !
Higher and Faster
PostPosted: Wed Dec 04, 2013 12:30 am
Hey Rich, that may work for the short people but my head is already in to the canopy, no more room.
PostPosted: Wed Dec 04, 2013 12:47 am
Well believe it or not, you can change the sitting height significantly with how you place the canopy. You can notice several different windshield angles and canopy rake as you look across our wonderful fleet. Got go with what works for you.
PostPosted: Wed Dec 04, 2013 10:57 pm
Yes James is onto something here;
Bruce F noticed my canopy right away. 'Feisty' has a high skirt around the back. It raised the back of the canopy up a bit and increases the headroom. Good thing too, as I barely fit.
I look at it as a source of drag, maybe 'Feisty' would be faster if the rear skirt were more fair, but then I wouldn't be flying in it, so I look for improvements somewhere else.
PostPosted: Thu Dec 05, 2013 7:55 am
Many of us jacked the roll bar up 3/4" over standard when building. The original canopy had just enough extra meat to cover this, but did not fit the "S" very well. The Airplane Plastics version takes care of the problem.
PostPosted: Thu Dec 05, 2013 1:27 pm
Here's my canopy. It does have the 3/4" added to the roll bar plus I raised the canopy another two inches. This canopy is from Aeroplane Plastics. Looking at the cross section of the canopy it becomes an airfoil. I have not seen a reduction in speed as I cruise at 24/23 and indicate 180 mph plus at sea level.
