| Can wide body Thorps carry more fuel? http://thorp18.com/thorpforum/viewtopic.php?f=9&t=7894 |
| Author: | cw21f [ Sat Feb 20, 2016 7:11 am ] |
| Post subject: | Can wide body Thorps carry more fuel? |
It seems that whether a discussion is about a standard or wide body Thorp fuselage, the standard 29 gallon tank is used. Wanted to know if the 2" width increase in the wide fuselage models translates into a 2" width increase for the fuel tank, thereby offering a little more fuel capacity? Thanks, Chris |
| Author: | fytrplt [ Sat Feb 20, 2016 7:38 am ] |
| Post subject: | Re: Can wide body Thorps carry more fuel? |
The firewall is the same in both models. The width increase is at cockpit rails. The tank area is virtually the same, so the same tank is used. See Dave Read's mod for more fuel. He increased the "belly" of the tank for more vvolume. |
| Author: | Lou [ Sun Feb 21, 2016 9:20 pm ] |
the factory tanks are the same-29 gal |
| Author: | david read [ Mon Feb 22, 2016 9:45 pm ] |
As Bob said I pooched out the radius portion of the tank somewhat without interfering with my toes. With modern avionics which are not as deep I also effectively pulled the tank away from the firewall 4". The combination gives a 40 gallon main tank. |
| Author: | Rv3maker [ Fri Dec 08, 2023 6:01 pm ] |
david read wrote: As Bob said I pooched out the radius portion of the tank somewhat without interfering with my toes. With modern avionics which are not as deep I also effectively pulled the tank away from the firewall 4". The combination gives a 40 gallon main tank. David, Do you have any pictures you can share of your custom 40g tank? I don't want to mess with wet wings or aux tanks, but would be interested in something similar to what you have done that would still allow a person to K.I.S.S. Rob rv3maker |
