| Tail vibration in flight http://thorp18.com/thorpforum/viewtopic.php?f=8&t=8801 |
| Author: | Ryan Allen [ Tue Oct 10, 2023 5:58 pm ] |
| Post subject: | Tail vibration in flight |
I was out flying the other day, and I happened to look over my shoulder at the stabilator and it was vibrating. I could most easily tell the tips of the stabilator was vibrating. I was in smooth air at about 155 KTAS, straight and level. Is that normal? I cant say I have ever looked over my shoulder in flight before. The tail connections are all tight as they should be. |
| Author: | James Grahn [ Fri Oct 13, 2023 11:22 am ] |
| Post subject: | Re: Tail vibration in flight |
No! Do not fly that plane until you research it. Look at your weights. Check the tightness of all of your bushings in the pitch control. Cubes |
| Author: | Ryan Allen [ Fri Oct 13, 2023 1:17 pm ] |
yep, i agree. no bueno. |
| Author: | flyingfool [ Fri Oct 13, 2023 4:37 pm ] |
My first thought is to verify the counterweight is installed on/in the tail and the spar doubler is installed. I find it hard to believe that safety bulletin would not be complied with a LONG time ago. But it is worth the check for the cost of drilling out one or two rivets! |
| Author: | pmandel [ Sun Oct 15, 2023 10:20 am ] |
Feeling moved to chime in and emphasize -- PLEEEEEZE no further flight until this is diagnosed and fixed. Not even once around the patch. Stay on the ground. We don't want to read ABOUT you, we want to read something FROM you telling us what you found and how you fixed it. Thank you. |
| Author: | Jeff Blanton [ Mon Oct 16, 2023 7:50 am ] |
A bad wing to fuselage seal can cause a tail vibration. |
