| What lubricant do you use on your hinges? http://thorp18.com/thorpforum/viewtopic.php?f=8&t=8633 |
| Author: | Ryan Allen [ Sun Sep 05, 2021 8:14 am ] |
| Post subject: | What lubricant do you use on your hinges? |
I'm curious what lubricant everyone uses on your hinges. I have used WD-40, but that attracts so much dirt, there has to be a better option. |
| Author: | fytrplt [ Sun Sep 05, 2021 4:08 pm ] |
| Post subject: | Re: What lubricant do you use on your hinges? |
I have used BoeShield. It carries into the hinge and then leaves a thicker lubricant after it dries. Not as messy as motorcycle chain lube. |
| Author: | Jim Mantyla [ Sun Sep 05, 2021 8:47 pm ] |
I use LPS2. Se e ms. To work for me. Jim |
| Author: | Jeff J [ Mon Sep 06, 2021 7:00 am ] |
I don’t use WD-40 as a lubricant on anything. It works well to remove water from electrical connections (what it was designed for). LPS 2 and REM oil work well for hinges. |
