| Easy tool for removing Cylinder Head Bolts http://thorp18.com/thorpforum/viewtopic.php?f=8&t=7855 |
| Author: | Bill Williams [ Wed Nov 11, 2015 12:35 pm ] |
| Post subject: | Re: Easy tool for removing Cylinder Head Bolts |
I assume you have a stove bolt chevy in your plane as my Lycoming uses nuts to hold cylinders on. The head is part of the cylinder assembly. You need to use caution using a crows foot as not to round off the nut. Lycoming wrenches are not that expensive. |
| Author: | jrevens [ Wed Nov 11, 2015 6:10 pm ] |
Well done... that looks good! As I'm sure Bill knows, many older Lyc's used Allen socket round headed cylinder nuts. I've got a set of wrenches for them. |
