It is currently Sat Aug 29, 2026 11:22 am
 Post subject: Post your POH Here
PostPosted: Wed Nov 19, 2014 9:42 pm
Does anyone have a POH in WORD that I can shamelessly plagiarize and pass off as my own?
I had a couple of good ones, but I can't find them now. Bruce F, yours was one of them.
edwolff at bmts dot com
 Post subject: Re: Post your POH Here
PostPosted: Thu Nov 20, 2014 1:58 am
Dick,
You're in luck, I found it.
POH.doc [284.5 KiB]
Downloaded 9883 times
PostPosted: Fri Nov 21, 2014 10:22 am
Thanks Bruce, this will come in handy when 66WT is ready to fly In the spring.
PostPosted: Fri Nov 21, 2014 12:25 pm
Yeah, ditto! Better thank you publicly too so no one thinks I'm a jerk. ;-)
PostPosted: Fri Nov 21, 2014 1:16 pm
I should mention that my POH is still a work in progress, several areas need work particularly the performance section.
enjoy
PatrikB
PostPosted: Thu May 12, 2016 1:27 pm
Hello! I am the owner of one of the three Thorp were stationed in Sweden!
I bought from the builder and have fly IT for à year! Realy fun to fly!
Totaly time of the plane is soon 1300 h.
I have aerobatic rating so i have plan to fly soft aerobatic but the plane is not tested for it!
Im locking for à PO for à plane whish it tested for it and have the speeds for the manovers so i can get it approved in Sweden
TonyNZ
PostPosted: Sat May 14, 2016 12:28 am
Images: 8
Here is a copy of my POH. 9 WORD docs so you should be able to amend and delete ref to my aircraft and add yours.
Cheers
Tony S
ZK-VMS
T18C
THORP T18C FM Sect 0 9-12-01.doc [1.64 MiB]
Downloaded 1541 times
T18C FM Sect 9.doc [23.5 KiB]
T18C FM Sect 8.doc [27 KiB]
Downloaded 7547 times
T18C FM Sect 7.doc [337.5 KiB]
Downloaded 1577 times
T18C FM Sect 6.doc [45 KiB]
Downloaded 1373 times
T18C FM Sect 5.doc [64 KiB]
Downloaded 1430 times
T18C FM Sect 4.doc [1.49 MiB]
Downloaded 1429 times
T18C FM Sect 3.doc [57 KiB]
Downloaded 1700 times
T18C FM Sect 2 27-12-01.doc [40 KiB]
Downloaded 1366 times
T18C FM Sect 1 27-12-01.doc [238 KiB]
Downloaded 1513 times
090909 THORP T18C POH.doc [28 KiB]
Downloaded 1588 times
PatrikB
PostPosted: Sun May 15, 2016 3:35 pm
Thanks... But I dont find the rekomended airspeeds for manovers...only at the aircraft is proven for rolls and loops..
Mine is à ordinary T18...first flight -89 (SE-XGA)
PostPosted: Sun May 15, 2016 4:06 pm
No one is going to recommend those speeds in an experimental airplane. Do what I did: experiment and find out for yourself.
PostPosted: Sun May 15, 2016 4:10 pm
You MIGHT find what you are looking for if you dig through the old news letters. The lawyers didn't rule the country in those days.
DW
PostPosted: Sun May 15, 2016 4:34 pm
A T18 with a fixed pitch prop will do a loop at an entry speed of 165kts if you pull 3 Gs. If you have a CS, or pull different Gs, you will have to change the entry speed.
TonyNZ
PostPosted: Sun May 15, 2016 4:46 pm
Images: 8
Mine is a T18 with the C wing and original air foil and 150 hp fixed pitch. Aileron roll 140Kts, loop 145-150Kts, barrel roll 140Kts.
BUT before you do this you should know how your aircraft spins and more importantly how you recover it just in case you stuff up a manoeuvre.
Have fun
Tony
ZK-VMS
T18C
[ Time : 0.484s | 10 Queries | GZIP : On ]
