It is currently Sat Aug 29, 2026 7:04 pm
 Post subject: First Flight NX115RX
PostPosted: Sat Feb 15, 2014 12:32 am
[YouTube]http://youtu.be/bZVBf9sVP_8[/YouTube]
Already 3 years !
 Post subject: Re: First Flight NX115RX
PostPosted: Sat Feb 15, 2014 12:39 am
Well...I failed at you tube . Just go to You Tube and type in Rich Brazell and see all the action .
PostPosted: Sat Feb 15, 2014 8:50 am
You didn't really fail RB ... You may want to spell YouTube right though ;)
Needs to be "YouTube.com"
PostPosted: Sat Feb 15, 2014 9:55 am
Bing. Boom. ;)
PostPosted: Sat Feb 15, 2014 12:17 pm
Well...I'll try it again . I only typed what was on the You Tube site as the http://youtu,be/bZVBf9sVP_8 .
PostPosted: Sat Feb 15, 2014 3:09 pm
OK...I broke the code . ;) First Flight April 3rd , 2011 . Hard to believe it's been 3 years . BOOM !
Gerry R
PostPosted: Sat Feb 15, 2014 5:38 pm
Nice job, Rich.
Looks great. I think I saw this video a while back though. Maybe last summer when I was searching for T18 videos.
Gerry
PostPosted: Sat Feb 15, 2014 10:07 pm
That's a good Video Rich, your plane looks as good today as it did then......Dan
PostPosted: Sat Feb 15, 2014 11:19 pm
Thanks Dan ! Doing the annual and along with the usual inspection items , I am also doing some cosmetic clean up on the paint .
PostPosted: Sun Feb 16, 2014 10:22 pm
Got thought the annual, Done. As as supplement I did pull my tank today! Will start reassembly next weekend. Dan
PostPosted: Sun Feb 16, 2014 10:43 pm
That is a job ! You should be in bed by now !
PostPosted: Mon Feb 17, 2014 8:48 am
It was probably a good thing I pulled the tank, the Cork gasket under the sender unit on top of the tank had given up, or it was starting to. I went ahead and made a neoprene gasket for the new one, I will HI-Tack it on there and and wont have to worry about it. Im not going to do this again that's for sure, I got ahold of the same setup Bob has and he reported his being trouble free, I should be worm food before it quits again. I will continue to use my fuel stick, it has proven to be vey accurate. As I fill the tank( with waterline I believe it #42) level I will make note of what the guage reads... Dan
PostPosted: Tue Feb 18, 2014 10:19 pm
If you didn't put in an access cover for that sender I am going to send Nancy Pelosi to give you a good spanking !
Pacer 20
PostPosted: Tue Feb 18, 2014 10:24 pm
He Rich!!!
Why we never see your plane upside down during your video...
Pouet, pouet!!
Thierry
French Canadian T-18
C-FPVE #091
PostPosted: Wed Feb 19, 2014 12:22 am
I like the World right side up , straight and level , Max power to get to point B so I can laugh and scratch with my Pals ! ;) I had my thrills landing a jet on the Worlds shortest aircraft carrier and then getting thrown back into the air to do it all over again . CVT-16 . :o NO BIGGER BOOM THAN THAT !
[ Time : 0.128s | 11 Queries | GZIP : On ]
