| First Flight NX115RX http://thorp18.com/thorpforum/viewtopic.php?f=8&t=7523 |
| Author: | Rich Brazell [ Sat Feb 15, 2014 12:32 am ] |
| Post subject: | First Flight NX115RX |
[YouTube]http://youtu.be/bZVBf9sVP_8[/YouTube] Already 3 years ! RB
| Author: | Rich Brazell [ Sat Feb 15, 2014 12:39 am ] |
| Post subject: | Re: First Flight NX115RX |
Well...I failed at you tube . Just go to You Tube and type in Rich Brazell and see all the action . RB
| Author: | leewwalton [ Sat Feb 15, 2014 8:50 am ] |
You didn't really fail RB ... You may want to spell YouTube right though ![]() Needs to be "YouTube.com" |
| Author: | dickwolff [ Sat Feb 15, 2014 9:55 am ] |
Bing. Boom.
| Author: | Rich Brazell [ Sat Feb 15, 2014 12:17 pm ] |
Well...I'll try it again . I only typed what was on the You Tube site as the http://youtu,be/bZVBf9sVP_8 . RB
| Author: | Rich Brazell [ Sat Feb 15, 2014 3:09 pm ] |
OK...I broke the code . First Flight April 3rd , 2011 . Hard to believe it's been 3 years . BOOM !RB
| Author: | Gerry R [ Sat Feb 15, 2014 5:38 pm ] |
Nice job, Rich. Looks great. I think I saw this video a while back though. Maybe last summer when I was searching for T18 videos. Gerry |
| Author: | dan [ Sat Feb 15, 2014 10:07 pm ] |
That's a good Video Rich, your plane looks as good today as it did then......Dan |
| Author: | Rich Brazell [ Sat Feb 15, 2014 11:19 pm ] |
Thanks Dan ! Doing the annual and along with the usual inspection items , I am also doing some cosmetic clean up on the paint . RB
| Author: | dan [ Sun Feb 16, 2014 10:22 pm ] |
Got thought the annual, Done. As as supplement I did pull my tank today! Will start reassembly next weekend. Dan |
| Author: | Rich Brazell [ Sun Feb 16, 2014 10:43 pm ] |
That is a job ! You should be in bed by now ! RB
| Author: | dan [ Mon Feb 17, 2014 8:48 am ] |
It was probably a good thing I pulled the tank, the Cork gasket under the sender unit on top of the tank had given up, or it was starting to. I went ahead and made a neoprene gasket for the new one, I will HI-Tack it on there and and wont have to worry about it. Im not going to do this again that's for sure, I got ahold of the same setup Bob has and he reported his being trouble free, I should be worm food before it quits again. I will continue to use my fuel stick, it has proven to be vey accurate. As I fill the tank( with waterline I believe it #42) level I will make note of what the guage reads... Dan |
| Author: | Rich Brazell [ Tue Feb 18, 2014 10:19 pm ] |
If you didn't put in an access cover for that sender I am going to send Nancy Pelosi to give you a good spanking ! RB
| Author: | Pacer 20 [ Tue Feb 18, 2014 10:24 pm ] |
He Rich!!! Why we never see your plane upside down during your video... Pouet, pouet!! |
| Author: | Rich Brazell [ Wed Feb 19, 2014 12:22 am ] |
I like the World right side up , straight and level , Max power to get to point B so I can laugh and scratch with my Pals ! I had my thrills landing a jet on the Worlds shortest aircraft carrier and then getting thrown back into the air to do it all over again . CVT-16 . NO BIGGER BOOM THAN THAT !RB
