| pictorial pilot auto pilot http://thorp18.com/thorpforum/viewtopic.php?f=8&t=7455 |
| Author: | james peran [ Mon Nov 11, 2013 2:52 pm ] |
| Post subject: | pictorial pilot auto pilot |
I got a pictorial pilot auto pilot . On last flight it turned Stb about 5 degrees . Looked at connections they all seems tight . The aircraft will not fly straight with the auto pilot engaged .Any one had similar Problem??? J.P. |
| Author: | fytrplt [ Mon Nov 11, 2013 5:51 pm ] |
| Post subject: | Re: pictorial pilot auto pilot |
Make sure you get a good alignment on the ground. Even wind moving the plane while aligning can affect the performance. |
| Author: | Rich Brazell [ Mon Nov 11, 2013 10:40 pm ] |
JP : I suggest you go to the Tru Trak web site forum . You may be able to find someone there that has your problem , if not Lucas "the man" from Tru Trak may be able to help pin point the problem . RB Higher and Faster |
| Author: | james peran [ Tue Nov 12, 2013 2:30 am ] |
Thanks guys I will reprogram the auto pilot on the ground and see what happens . . JP |
