It is currently Wed Oct 14, 2026 7:50 pm
PostPosted: Sun Sep 05, 2021 8:14 am
I'm curious what lubricant everyone uses on your hinges. I have used WD-40, but that attracts so much dirt, there has to be a better option.
PostPosted: Sun Sep 05, 2021 4:08 pm
I have used BoeShield. It carries into the hinge and then leaves a thicker lubricant after it dries. Not as messy as motorcycle chain lube.
PostPosted: Sun Sep 05, 2021 8:47 pm
I use LPS2. Se e ms. To work for me.
PostPosted: Mon Sep 06, 2021 7:00 am
I don’t use WD-40 as a lubricant on anything. It works well to remove water from electrical connections (what it was designed for). LPS 2 and REM oil work well for hinges.
Users browsing this forum: No registered users and 20 guests
[ Time : 0.093s | 9 Queries | GZIP : On ]
