I have the 550 x 5 standard axel with a wheel pant stub. End is tapped for a 1/4 x 28 screw/bolt. Like Bill I cut an aluminum spacer to fit between the axle and the pant. I put a doubler on the inside of the pant and on the outside and run a 1/4 screw with a star lock washer thru the spacer into the tapped hole in the axel.
From the one pic of the unpainted pant you can see the rivets for the doubler which is also part of the small access door I use to access the tire valve stem. With almost 80 hours on the "new pants" the attach screw has remained tight.
