It is currently Sun Apr 28, 2024 4:28 am
Bill Morse
PostPosted: Tue Jun 14, 2011 9:07 pm
Does anyone have the so called heavy duty mod for the Cleveland brakes and 66-108 pads? If so, what is the thickness of the shim added to make the "heavy duty" part of the system.
200 hours or so on pads seems slight. I have noticed that the inboard pads do not wear fully (around 50%) because the piston limits travel as it contacts the outboard caliper/pad bracket, if you will. Shimming the inboard pad would give more use, however there is the potential for the rivets to contact the disc.
Bill
William Morse
[ Time : 0.220s | 12 Queries | GZIP : On ]
