| converting 600x 6 To 500 x 5 axles http://thorp18.com/thorpforum/viewtopic.php?f=7&t=6243 |
| Author: | wberken [ Mon Aug 30, 2010 7:16 pm ] |
| Post subject: | converting 600x 6 To 500 x 5 axles |
I am trying to convert my wheels from exisitng 600 x 6 to 500 x 5 wheels. My 600 x 6 wheels have a axle diameter of 1 1/2 inches. My 500 x 5 have a diameter of 1 1/4 inches. I have tried to attach a photo of my existing gear bolt pattern, but have not succeeded. Can anyone help how to attach the photo?? The axles I have with the 500 x 5 are on a small square pattern. Can anybody help or have any suggestions. Bill photo is on page 57 *** photo inserted by admin *** |
| Author: | leewwalton [ Mon Aug 30, 2010 7:39 pm ] |
To insert a photo, edit your post and click the paperclip in between "Attach Photo" and "Insert an image file", a pop up will appear, select the pic you want and click "insert" |
| Author: | Hoov330 [ Tue Aug 31, 2010 1:31 pm ] |
I cant seem to do it either. I change it to a zip file and when I go to upload it my computer locks up. |
| Author: | Rich Brazell [ Tue Aug 31, 2010 3:08 pm ] |
Hummm? Not the plans built hub that came welded on my gear. I don't remember seeing an axel with this bolt pattern in any catalog I have ? RB |
| Author: | leewwalton [ Tue Aug 31, 2010 7:30 pm ] |
Will you guys please send me a note and tell me exactly what you are trying to do, and how you are doing it? Not sure why you are trying to upload an image as a zip file. I understand some guys are having difficulties uploading pics, if you tell me the error message I can get to the bottom of it. |
| Author: | wberken [ Tue Aug 31, 2010 7:48 pm ] |
Thank you very much for looking. I feel the builder must have made his own gear. I quess I have a problem and will have to fabricate new axles. Thanks again. Bill Berken |
| Author: | Rich Brazell [ Tue Aug 31, 2010 8:23 pm ] |
Bill: If you have a pic of the actual axel/wheel assembly, maybe someone that worked on the Los Angeles class of airships [:0], might have an idea with what we're dealing with...just kidding about the Air Ship part ! You might be able to get a welder to weld on the "plans part" of the hub so you can use the "store bought" bolt on axels. I am not a welder, so not quite sure what's involved with doing that. I would be interested in what type of wheel/brake assembly goes on that round hub of yours...no lack of bolts to hold it on ! [:p] My first thought when I saw the pic of the hub was that the builder had a "surplus" wheel/axel/hub that he could use on the A/C. It must have worked ? Reason for changing it out ? No avail. parts ? RB NX115RX |
