Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Extended gear?
PostPosted: Fri Jan 18, 2013 11:29 am
You may have to explain that one Jim .. Not making much sence to me.
Scott Stine
PostPosted: Fri Jan 18, 2013 11:38 am
Images: 5
Think in the abstract Lee.....if the extensions were not there then the gear would not be long enough to reach the ground......probably need a few barley pops in your system to understand the engineering behind that comment.
Snap back to reality......seems to me like the numbers are adding up to enough people needing gear to justify a production run.......? Wasnt it 4 sets needed to justify the cost of production....?
SS
PostPosted: Fri Jan 18, 2013 11:44 am
Still not getting it ... Perhaps later on after a few coldies it'll come to me .
The gear delima .. That's a Bill Williams question. Willie?
cgifly2
PostPosted: Fri Jan 18, 2013 12:10 pm
Ok I have a dumb question. 7077J has a standard short (first plans) landing gear. I have 160 hrs ( hundreds ) of take offs and landings. Why is it that you guys are extending the gear?
Skeet
PostPosted: Fri Jan 18, 2013 12:44 pm
The per plans "short" gear does not put the airplane at a three point attitude. As a result people tend to land on the tail wheel first. To counter this back in the 1970 s the 2" extended gear became the norm. With the leaf tail wheel 2" puts the airplane at a three point, with the rod spring 1" does the trick.
We're extending short gears now as thorp landing gear are in short supply and the extensions effectively convert a short gear into a standard gear.
cgifly2
PostPosted: Fri Jan 18, 2013 12:49 pm
Ok I will keep that in mind if I ever have a problem with landing. Haven't yet so I doubt I will need to do that.
Skeet
PostPosted: Fri Jan 18, 2013 1:59 pm
Hi Guys, Thanks for all the photos and comments. The photo is of the left main gear. And yes the brakes are forward of the gear leg. With all that said, I plan on returning to the stock gear - no extensions. The brakes will go back to the aft position. I plan on removing the leaf tail spring and changing to the ACS tailwheel. Those combinations should give me the proper attitude on the ground and a good landing attitude.
Terry
PostPosted: Fri Jan 18, 2013 2:51 pm
Lee,
It's kind of like the girls that have to wear high heel shoes. If they didn't, their feet wouldn't reach the ground.
Have a great weekend.
PostPosted: Fri Jan 18, 2013 3:09 pm
I appreciate your sense of humour, Jim. I don't care what the rest say... you're a good man.
d
PostPosted: Fri Jan 18, 2013 3:40 pm
Thanks Jim, made me laugh out loud... Les Krumel
Jim Mantyla wrote:
Guys,
I think the set up in the picture Lee posted was done so that the wheels could reach the ground.
Jim :-)
bmooresbm
PostPosted: Fri Jan 18, 2013 4:14 pm
How much $ for a set from the "production run"?
Chasr263
PostPosted: Fri Jan 18, 2013 5:51 pm
This thread got me thinking about my gear so I checked the plans. The gear on my T-8 is a full 3 in longer than the plans. I was wondering if long gear was a common modification. Chuck
PostPosted: Fri Jan 18, 2013 6:25 pm
The longer gear is now considered standard.
PostPosted: Fri Jan 18, 2013 8:21 pm
Jim,
Just got it!! Thanks beer! Little slow today I guess.
Jim,
[ Time : 0.236s | 9 Queries | GZIP : On ]
