Canopy - Latch open
http://thorp18.com/thorpforum/viewtopic.php?f=6&t=8570
Author:  Ptbob484 [ Thu Dec 03, 2020 6:28 pm ]
Post subject:  Canopy - Latch open
Hi guys. Anyone know how to make the canopy stay open when one is taxing?
Author:  Jeff J [ Thu Dec 03, 2020 6:46 pm ]
Post subject:  Re: Canopy - Latch open
I block it with my arm.
Author:  TonyNZ [ Thu Dec 03, 2020 10:20 pm ]
Yep so do I.
Tony
ZK-VMS
T18C
Author:  fytrplt [ Sat Dec 05, 2020 7:10 am ]
Copilot's duty during run up.
Author:  Jeff J [ Sat Dec 05, 2020 10:10 am ]
I flew with it unlatched one day. I was by myself and the canopy closed at the beginning of the run up. By the time I finished the run up I had forgotten about it. No harm done but now I latch it shut before I do the run up.
Author:  Tony Ginn [ Sat Dec 05, 2020 3:21 pm ]
I bent up a stainless steel tab that catches the roller bearings in their aft-most position. Works great.
Author:  jrevens [ Sun Dec 06, 2020 12:16 am ]
"I bent up a stainless steel tab that catches the roller bearings in their aft-most position. Works great."
I think I'm the one who came up with that idea quite a few years ago, Tony... works pretty well, especially if you don't have a lot of sidewall upholstery in that area. I know I sent some stainless material to your brother for that purpose back when.
Author:  ScottECG [ Sun Dec 06, 2020 5:46 am ]
I can confirm that 149RH has an identical tab John. Tony, Did you make it for Scott?
Author:  Rich Brazell [ Sun Dec 06, 2020 2:41 pm ]
Made mine from scraps in the where did I put that drawer ? ::) Nothing more than a small piece of angle , a piece of spring steel and a nylon latch made from some left over nylon strip . I also used miniature screws and nuts . :P To keep the canopy open I push with one hand to the full open position and then push foward on the canopy to seat the frame in the nylon latch . To close push the canopy full open with one hand hold open the nylon latch portion and then push the canopy frame past the nylon latch . :o BADA BING , BADA BOOM ![b][/b]
