It is currently Tue Apr 16, 2024 1:56 pm
blackopsspook
 Post subject: K3L-3 roller bearings
PostPosted: Mon Sep 18, 2017 6:10 pm
Okay guys and gals, I'm looking for a good source for K3L-3 roller bearings to replace the very old ones during my rebuild. I've examined the bearings I currently have and they definitely need to be replaced. The issue is that I don't seem to be able to find them readily available, so I was wondering if anyone had any spares they would be willing to sell me. Yes, I need to replace every roller bearing. My plane i.e. N18VP was built by Taylor in 1969 and I'm basically having to do extensive work to get the plane back into flying condition because the previous owner neglected it.
I would appreciate any roller bearings that you might have guys.
L...
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." --Douglas Adams
::N18VP::
PostPosted: Mon Sep 18, 2017 6:12 pm
You asking about the canopy bearings?
PostPosted: Mon Sep 18, 2017 9:30 pm
3/4" shower door rollers from Ace Hardware. Get the squared off kind.
blackopsspook
PostPosted: Tue Sep 19, 2017 7:44 am
Hi Bill and Bob!
Yes, I'm referring to the canopy roller bearings. Sorry if I didn't make that very clear. Bob I've seen the postings for the shower door rollers, I was just trying to duplicate the original parts. That being said, if I cannot find a source for K3L-3 roller bearings then I may have to do as you suggest.
BTW, I'm happy to see you guys came through Irma relatively unscathed. I love Florida after living there for so long, but I don't miss hurricane season! :)
Thank you gentlemen!!
L...
::N18VP::
PostPosted: Tue Sep 19, 2017 10:28 am
Shower rollers better. Don't wear the rail as much. You really don't want to replace the rail. Big job.
james peran
PostPosted: Tue Sep 19, 2017 5:53 pm
L...
I got the original bearings . i can supply them . peranjames@gmail.com
PostPosted: Tue Jan 02, 2018 1:35 pm
Thanks for the tip on the shower rollers. It just saved me $100 over buying through spruce.
PostPosted: Sun Jan 07, 2018 2:01 pm
well, I just figured out that since my canopy frame is already drilled, the shower roller bearings wont work. The shower roller bearings are .75" outside diameter and the K3L3 bearings are .635" outside diameter. Meaning the shower bearings are too big for my pre-drilled holes.
PostPosted: Sun Jan 07, 2018 2:07 pm
JP sez he has the bearings ! :P
PostPosted: Sun Jan 07, 2018 2:21 pm
Search Ebay for 625ZZ single row bearing. These are .625 x 3/16 plus
james peran
PostPosted: Mon Jan 08, 2018 12:40 am
Yes i still got some Bearings . $ 15 each plus postage J.P.
PostPosted: Mon Jan 08, 2018 11:40 am
I believe I still have them as well. I'll have to check when I get back home.
PostPosted: Mon Jan 08, 2018 7:22 pm
I bought some of these from Spruce prior to seeing all the suggestions: KP3A HEIM BEARING KP3A
Its good to know the K3L3 bearings are available should the ones from Spruce not fit good.
[ Time : 0.148s | 13 Queries | GZIP : On ]
