Aircraft Spruce MC-4 nose cowl?
http://thorp18.com/thorpforum/viewtopic.php?f=5&t=8259
Author:  Cook11 [ Thu Aug 16, 2018 4:33 pm ]
Post subject:  Aircraft Spruce MC-4 nose cowl?
Can anyone supply me some pictures of what the Aircraft Spruce MC-4 nose cowl looks like? Also what prop spinner fits this nose cowl?
Thanks!
Author:  Jeff J [ Fri Aug 17, 2018 7:48 am ]
Post subject:  Re: Aircraft Spruce MC-4 nose cowl?
I hope this helps: https://www.skyshop.com.au/pdf/2009-201 ... %20196.pdf
Author:  Hagle347 [ Fri Aug 17, 2018 3:18 pm ]
I’m sure Cubes has the appropriate spinner for this application whether you go fixed pitch or constant speed
T
Author:  Hagle347 [ Fri Aug 17, 2018 3:22 pm ]
I believe Bernie has the nosebowl you ask about
Author:  Cook11 [ Thu Aug 23, 2018 11:50 am ]
Thanks for the info guys!
Author:  thorpdrvr [ Fri Aug 24, 2018 2:45 pm ]
I have the Aircraft Spruce MC-4 nose bowl with the MC-5 bottom pan. The spinner is a BN-3 from Spruce also. The cowl was slightly larger than spinner trailing edge, so did some work on cowl to make it match spinner. The cooling air inlets were closed up a bit and the bottom pan was modified with the exhaust outlets and ram air intake.
Author:  Rich Brazell [ Fri Aug 24, 2018 5:17 pm ]
One of the nicest T-18's I've seen !
