| Prop Spinner http://thorp18.com/thorpforum/viewtopic.php?f=48&t=8001 |
| Author: | denndowning [ Wed Oct 12, 2016 10:01 am ] |
| Post subject: | Prop Spinner |
My prop spinner has a crack and needs to be replaced. It's an aluminum spinner on a Hartzell constant speed, which is on an IO360. It looks like the Hartzell C1904-3 Propeller Spinner Dome would do the trick, but I don't really want to spend $600 for a certified spinner. Does anyone know of any other source for a spinner that would fit? |
| Author: | James Grahn [ Wed Oct 12, 2016 10:58 am ] |
| Post subject: | Re: Prop Spinner |
I have spinners in stock. Cubes |
| Author: | denndowning [ Wed Oct 12, 2016 8:34 pm ] |
Cubes - Someone just "gave" me a Van's constant speed spinner, so I'm going to see if I can get it to work on the Thorp. If it doesn't work out, I'll be getting back with you to order one. Thanks. Dennis |
| Author: | Rich Brazell [ Wed Oct 12, 2016 9:54 pm ] |
I have an ACS spinner that developed a crack on the large radius cutout portion of the spinner . An A&P knew an "aerospace welder" that specialized in aluminum welding (also hot sections on jet engines) and welded the crack . When he was done you could not even tell there was a crack looking at the outside of the spinner . It was blended so well . You could see a small trace of the weld bead on the inside, but it too was smoothed out nicely . Have about 50 hours on it now and no evidence of further cracking . I did buy another ACS spinner and increased the size of the radius cutout and hopefully that will curtail any future cracks ? RB BaBaLoo |
| Author: | Jim Mantyla [ Sun Aug 06, 2017 8:59 am ] |
Guys, I used the spinner from Cubes and am really happy with it. The runout is less than .005". Definitely a quality spinner and cheap as well. Regards, Jim |
| Author: | stevehawley [ Mon Aug 07, 2017 4:16 pm ] |
I bought one of the carbon fiber ones that Lee makes and sells and have been very happy with it. It has been on for about three years and has never given any problems at all. Steve Hawley |
