It is currently Tue Nov 03, 2026 8:07 am
PostPosted: Fri May 04, 2012 9:52 am
I have a left hand Infinity Aerospace Stick Grip available that I'm not going to use. This retails for $175, I'll let it go for $100.
Just to clarify this is stick in left hand / throttle in right, it will not work for a left hand throttle set up. I guess it would technically "work" but it just wouldn't feel "right"
See pics.
PostPosted: Fri May 04, 2012 3:30 pm
Now you tell me ! Just installed two of the Infinity grips.
Brent Schultz
PostPosted: Sun May 06, 2012 6:52 am
Lee,
Its just what I need. I will take as we have center throttle on our new Thorp.
Brent Schultz
N6CM
PostPosted: Sun May 06, 2012 1:15 pm
Ok Brent it's all yours.
Brent Schultz
PostPosted: Sun May 06, 2012 7:04 pm
Lee,
Where should I send the check
Brent
PostPosted: Sun May 06, 2012 7:08 pm
Here you go Brent ...
5000 Schuler unit E
Houston, TX 77007
Is the Teton Ave address ok for you?
Brent Schultz
PostPosted: Wed May 09, 2012 10:55 am
Lee,
I just put check in the mail. Would appreciate you mailing stick grip to me. Send it to:
Brent Schultz
6048 East Teton Avenue
Orange, CA
92867
Thanks for helping get our Thorp back in the air!
Brent
PostPosted: Wed May 09, 2012 11:08 am
On the way Brent ... was just waiting to make sure the address was correct.
Brent Schultz
PostPosted: Fri May 18, 2012 4:39 pm
Lee, I got the stick grip. Thanks!!!!
Brent Schultz
PostPosted: Fri May 18, 2012 4:48 pm
Good deal Brent! Now find a use for all those buttons, switches and trigger! ;)
PostPosted: Fri May 18, 2012 4:51 pm
Btw you'll need to make a spacer to put that on the 3/4 thorp stick. I used a piece of 1" dia 1/8 wall alum tubing. That brings the 1" grib down to the 3/4" stick.
Brent Schultz
PostPosted: Fri May 18, 2012 5:57 pm
I thought the stick hole looked a bit big. That's no problem. We have plenty if metal tubing stock to make the spacer. Did u use that momentary switch on the top to actuate the flaps. We bought the actuator u recommended. Also, what would u use those other two buttons on the right for? Maybe to change comm frequencies or the Garmin GPS?
PostPosted: Fri May 18, 2012 7:02 pm
Go to the Infinity Web page. It has the drawing for the required spacer for our sticks. I had to remove the "blue insulation" from the main wire and solder all the grounds to a common point in order to reduce the number of wires going down the stick and out the bottom. Got this tip from another site ? You can buy the required spacer from Infinity for $15.00. Took me about 15 min. to make mine. When I install electric flaps, I will have one spare switch on the grip. The flap switch is the toggle switch with up/on and mom. down.
PostPosted: Sun May 20, 2012 3:06 pm
Don't forget to offset the grip. If you don't put in the twist/offset your wrist will get mighty tired ! :o Looking straight down from the top of the grip for the pilots side the PTT trigger will be pointing slightly to the co-pilots side. ;)
PostPosted: Mon May 21, 2012 6:14 am
Unless the throttle is on the left, FIGHTER style!
[ Time : 0.298s | 11 Queries | GZIP : On ]
