| Prop and Spinner wanted http://thorp18.com/thorpforum/viewtopic.php?f=48&t=6863 |
Page 1 of 2 |
| Author: | dickwolff [ Tue Dec 13, 2011 9:40 pm ] |
| Post subject: | Prop and Spinner wanted |
Looking for a good prop for an O360, ideally with a Thorp-sized spinner. Dick Wolff edwolff @ brucetelecom dot com |
| Author: | Rich Brazell [ Tue Dec 13, 2011 11:27 pm ] |
| Post subject: | Re: Prop and Spinner wanted |
AD prop. BN-3 spinner kit from Spruce...made for the Lycoming and fits the cowling, (you have to do the cut outs). If you need a crush plate and extension...Saber products. He even has the correct prop bolts. This is the package I used and have been very happy. Assuming you are looking for a wood prop ? The spinner has tooling marks on it and will need polishing. Spruce can do the polishing for a price.RB |
| Author: | chuck [ Tue Dec 27, 2011 5:43 pm ] |
Dick, I have a Sensenich 70/77 1/2 bolts with spinner and bulkheads, has about 100 hours on it. I don't know if would fit an 0-360 it came off of my 0-320. Chuck |
| Author: | dan [ Fri Dec 30, 2011 9:57 pm ] |
Dick, check with Dean Cuke on that prop for the 360, I believe he has one in his Garage. Dan |
| Author: | dan [ Tue Jan 03, 2012 9:30 pm ] |
Hi Dick, I gave Dean your email,he will mail you in regards to the prop."....Dan |
| Author: | Bill Williams [ Wed Jan 04, 2012 7:27 am ] |
320's and 360 Lyc's have different prop bolts unless someone has changed the flange spools . The 320 has 7/16" bolts and the 360 has 1/2" bolts and will not interchange. |
| Author: | davem [ Wed Jan 04, 2012 10:37 am ] |
Depending on the model, some O-320s have 3/8" bolts lugs--the OD of the lug is otherwise the same as the 7/16" ones. I had one of each up until a couple of months ago. Dave M |
| Author: | dcuke [ Wed Jan 04, 2012 11:08 am ] |
@Dick, I sent you an email about the prop that I have for an O-360. I also attached some pics of it. |
| Author: | leewwalton [ Fri Jan 06, 2012 8:05 am ] |
Dick, This is worth looking into. The spinner alone sells for $425. http://www.barnstormers.com/listing.php?id=621038 |
| Author: | dickwolff [ Fri Jan 06, 2012 4:30 pm ] |
Nice... but isn't 76" a bit long for a Thorp? |
| Author: | leewwalton [ Fri Jan 06, 2012 6:23 pm ] |
Yes it is Dick, sorry didn't even look at the size of the prop .. the spinner would work on a thorp very well though. |
| Author: | N89BJ [ Mon Jan 09, 2012 11:24 am ] |
Rich Brazell wrote: O0 AD prop. BN-3 spinner kit from Spruce...made for the Lycoming and fits the cowling, (you have to do the cut outs). If you need a crush plate and extension...Saber products. He even has the correct prop bolts. This is the package I used and have been very happy. Assuming you are looking for a wood prop ? The spinner has tooling marks on it and will need polishing. Spruce can do the polishing for a price.RB Rich, Just noticed your prop in the strobe light picture. So is your AD prop painted like a Hartzell or are you running a metal prop? Thanks. |
| Author: | Rich Brazell [ Mon Jan 09, 2012 6:41 pm ] |
Nope...AD wood prop painted gray, white tips and black on the back side. More than more person has asked me if it was a metal prop ! They don't know it's wood until I tell them. RB |
| Author: | N89BJ [ Mon Jan 09, 2012 9:54 pm ] |
Rich, very nice. Byron |
| Author: | dan [ Mon Jan 09, 2012 11:36 pm ] |
Hey Rich, now I got several folks convinced that my prop is Metal, if you keep tellin folks they are wood, it's going to completely undo my story on organic aluminum!!! Dan |
