It is currently Wed Nov 18, 2026 2:26 am
BobMoe
 Post subject: REM37BY "SOLD"
PostPosted: Wed Jun 27, 2012 9:25 pm
Anybody need any REM37BY plugs. I found 18 for sale @ $10 a piece. PM me if you are interested.
Bob MO
Jeff Blanton
PostPosted: Wed Jun 27, 2012 10:01 pm
Sent you a PM Bob. I was just pricing these today.
Jeff
 Post subject: Re: REM37BY "SOLD"
PostPosted: Wed Jun 27, 2012 11:36 pm
Aye Carumba ! :o PM me next time and I'll buy 2 boxes ! ;)
Gary Green
PostPosted: Wed Jul 04, 2012 1:13 pm
I have several good, but used, REM37BY plugs that I'd give away. I don't use'm any more. I just installed 8 new NGK BR8ES plugs a couple days ago---cost me $20 for all eight.
Gary Green
PostPosted: Wed Jul 04, 2012 4:01 pm
What electronic ignition did you install, Gary? Did it meet expectations?
d
Gary Green
PostPosted: Thu Jul 05, 2012 11:32 am
I have dual P-Mags. Well actually one E-Mag and one P-Mag. They no longer make the E-Mag model---all are now the P-Mag style. I like them enough that I put dual P-Mags on the O-200 that I am using on the Cub.
GG
PostPosted: Thu Jul 05, 2012 6:17 pm
Do they really improve fuel consumption in the order of 10%? If so, there's a real payback.
PostPosted: Thu Jul 05, 2012 10:32 pm
Gary, if you have a minute could you give us the low down on the p-mag. I talked to the gentlemen in Texas I believe it was and these guys appear to have their acts together. This electronic stuff seems to be the way things are heading, tell us your story on this if you don't mind...Thanx. Dan
Gary Green
PostPosted: Fri Jul 06, 2012 1:00 pm
I don't know if I achieve much better gas mileage with the electronic ignition. I generally run at 55-60% power and burn about 8 1/2 GPH with TAS of 180 mph. That is what my old Thorp (N118GG) did with Bendix mags. What I really like is how it starts, how smooth it is, how slow it will idle (570-600 rpm), etc. There is virtually no maintenance required, timing could hardly be more simple. I change plugs about every 100 hours because they are so inexpensive that it doesn't seem worth it to clean and re-install them. Brad Dement at EMAGAIR is a straight shooter. They did have some teething problems with their very early models but that was several years ago and the design has gone through several iterations. I have not heard of any complaints for a long time. I think their current design has matured into a robust, reliable unit. They are a bit pricey. The slight fuel savings would take a long time to make up for the price differential over a new set of mags.
GG
PostPosted: Fri Jul 06, 2012 10:32 pm
Thanks Gary, they did have some troubles, But it sounds like they took the info from what troubles they did have and used it to make a solid unit. I agree, these guys are a couple of the sharpest tacks in the drawer and they are very professional. Which mode do you use on your units, mag mode? Or do you use one of the more advanced modes. thanks Gary. Dan
Gary Green
PostPosted: Sat Jul 07, 2012 12:56 pm
I just use the standard advance curve that comes installed.
GG
dondday
PostPosted: Thu Jul 12, 2012 5:21 pm
Images: 29
Gary,
Do you have to install heat risers to use the NGK BR8ES?
D-Day
[ Time : 0.240s | 9 Queries | GZIP : On ]
