It is currently Fri Nov 20, 2026 5:19 am
 Post subject: 1974 T18
PostPosted: Fri Jan 16, 2026 12:05 pm
O-320-B3B 75 SMOH. Sterba prop. 1076 TTAF. ICOM radio. Sigtronics intercom. Garmin G3 MGL engine monitor. no transponder or encoder. I always use Cam Guard. Pmag on right side. Slick on left. Complete set of plans.
At a minimum it needs a cylinder and elevator trim actuator to fly. I wasn’t flying it enough so the #2 cylinder rusted up. It was a concern at 3 SMOH when I bought the airplane but was fine as long as I flew it regular. The last T18 entry in my logbook was in February 2021. Last completed condition inspection was March 2020. I haven’t done anything with it since I discovered the bad cylinder.
Located at F08. $15,000.
 Post subject: Re: 1974 T18
PostPosted: Fri Jan 16, 2026 1:56 pm
Here are a few pictures.
Thorp Aircraft
PostPosted: Tue Jan 20, 2026 8:08 am
Jeff,
Would you please give me a call at 210-529-7977?
Thank you,
Alex Pearson
Thorp Aircraft
Alex Pearson
Thorp Aircraft
alex@thorpaircraft.com
(210) 365-3374
PostPosted: Sat Feb 28, 2026 6:24 pm
I don’t know if anyone is actually watching the forum anymore but I have a correction and an update. There is a Garmin G5, not G3, installed. And someone brought a borescope to the airplane today and we found corrosion in all 4 with #4 appearing to be worst. We were going to pull a jug to check the cam but my cylinder wrenches are MIA.
There are still a lot of good parts here. I would hate to break it down to sell the pieces. Make me an offer.
PostPosted: Sat Feb 28, 2026 8:07 pm
what a bummer Jeff. Good luck with it. Hopefully someone will get it back in the air.
PostPosted: Mon Mar 02, 2026 9:38 am
It looks like it may see the skies again. Sale pending.
[ Time : 0.254s | 12 Queries | GZIP : On ]
