Bob Clayton's T-18 for sale in Utah
http://thorp18.com/thorpforum/viewtopic.php?f=46&t=8009
Author:  Fraser MacPhee [ Mon Oct 31, 2016 2:52 pm ]
Post subject:  Bob Clayton's T-18 for sale in Utah
Mr. Clayton's Opus - beautifully built Thorp T-18 for sale. Defines craftsmanship - Based at Skypark in Utah (KBTF).
101 Hours Total Time A&E, 0290 D with Aymar Demuth Prop - 150 MPH on about 5.5 GPH behind a reliable and smooth running 0-290D.
John Thorp Style "Convenience" Wheel Pants - can work on brakes and air up without removal.
5 point harness - lightweight starter - Garmin 496.- Remote Oil Filter - Remote Oil Cooler - Coated Exhaust - stall strips
This is a wonderful aircraft that is (I found) easy to fly, tracks straight and true on landing and will last a long time. Call Bob Clayton - 801-209-1949 or myself (801-860-0133) for more bona fides. - Asking $30K but will entertain reasonable offers. It's practically brand new and always hangared.
Edit - I flew this plane last Saturday with a full tank and it was indicating 140 MPH at 2500 RPM without the gear leg fairings and upper cuffs. Should be 150ish when all faired out - Bob is installing the gear leg fairings and has the upper cuffs on order. We will have them installed in a month or so.
This plane is a good fit for those of my size (5'8.517" tall X 185lbs dressed out) and/or better looking. Larger and less pretty folks might find it a teeny bit cramped.
You can also email me at p51par5@msn.com.
Author:  fytrplt [ Mon Oct 31, 2016 5:38 pm ]
Post subject:  Re: Bob Clayton's T-18 for sale in Utah
Is this the same plane that was under construction in Ogden in the mid to late seventies? Mine was U/C there at that time.
Author:  Fraser MacPhee [ Mon Oct 31, 2016 6:04 pm ]
Might be - he lived in Bountiful though - I think he has only had it in the hangar in Bountiful since the mid 90s
Author:  fytrplt [ Mon Oct 31, 2016 6:48 pm ]
EAA Chapter was in Ogden in those days.
Author:  DaveDABQ [ Wed Nov 02, 2016 10:37 pm ]
That is a beautiful Thorp.
I've been looking through the Newsletter Archive (an absolutely fantastic resource--thanks for scanning and uploading all that material!) and found NL 120 and 131 have articles about N818TR. May be more, just recently read these and made the connection...
Author:  Ryan Allen [ Sat Nov 05, 2016 3:08 pm ]
There is a write up on the Internet on Bob's EAA webpage about his first flight and a little info. Here is the link http://www.eaa23.org/pr-bob.htm
Below is the text of the web page. The pictures used to be on the webpage, but I couldn't get the pics to load up on the webpage this time. Don't know if its my computer or the pics have been moved.
Bob Clayton's - Thorp T-18
Thorp T-18 standard body plans #888 purchased in 1972, timidly began construction in 1973 and hope to be completed early summer 1999. Major items to complete at this date (24 Nov 1998) - cowling side doors, exhaust stack supports, canopy and windscreen and wing attachment and wing control hookup. Oh yes, and paint. Began construction on our living room floor and in 1976 moved into a new part time two car garage (mostly a hangar). Constructed with minimum basic shop tools (with a few of the small specialized aircraft tools necessary) and on saw horses (no specialized jigs). How is this done? Let me quote John Thorp from the early 60's.
"My system of building a metal airplane without jugs employs a system of locating the rivet holes in the detail parts through the use of transfer templates. With all of the holes in the parts, assembly is accomplished erector set fashion by clecoing parts into assemblies and then riveting. Aside from the obvious advantage of not being required to build jigs, this system has advantages of unusual component accuracy, convenient assembly sequence and simplified repair. "Matched hole" tooling has been used by various people in some degree for many years. Techniques vary between practitioners, but all are based upon the geometric theorem that "things equal to the same thing are equal to each other". If you have a set of holes in a flat sheet metal part and you want a number of additional parts identical to the first part you can use the first part as a tool and drill or punch the additional parts from the first part. Neglecting wear on the first part, all parts will be equal to each other. You can also transfer the hole pattern from the first part into a template and then use the template to locate the holes in the additional parts. The template pattern is identical to the first part and all additional parts have patterns identical to each other. If we use only reasonable accuracy in laying out a rivet pattern, and if we transfer the pattern exactly to its mating parts, the parts will go together and tolerance as such becomes of only academic interest. Airplanes are essential symmetrical. Parts on one side are frequently a mirror image of a corresponding part on the other side. If these parts have identical hole patterns and their mating parts have identical hole patterns the assemblies will be symmetrical and the airplane will fly straight. If we lay out a rivet pattern only once and make two parts at a time, we not only cut the labor virtually in half, but insure symmetry as well. Hole coordinating template techniques fit this scheme." It works! NOTE! The time I have spent working is not a reflection of John’s system of construction, but my inability to stay on task.
My engine - a 1950 stock Lyc 0290 D with about 85% new parts, assembled by Bob Despain at Precision Air in Salt Lake City. B&C starter and 40 amp alternator using a B&C LR-3 linear regulator. Exhaust system is a crossover system by Dean Cochrin with HPC High Performance Coatings inside and out. Piston skirts, valve springs, exhaust valves are also coated by HPC. The fuel system uses an Andair shutoff valve and gravity feed to the carb with a Skysports fuel probe for fuel quantity
I will turn a Sensenich W66LM72 wood prop. Full gyros with electric t&b, RST kit navcom, Narco transponder, RST kit intercom. Seats and upholstery by Ron Christensen.
I love my T-18!
Update! - First Flight 06/13/05 - Pilot, Danny Sorensen
The first flight of N818TR was conducted at approximately 09:30 on Monday, June 13, 2005, at Skypark Airport (BTF). Attendance was limited to a few family and friends. No public notice was made to the 'local flying community.
All preflight preparations completed. The passenger seat belts and shoulder harness were secured so as not to interfere with the flight controls. I strapped into the five-point harness and secured them tightly. All controls were checked to be within easy reach with the restraints secure.
Taxi to the active runway was completely normal as per prior taxi tests. Skypark uses a Unicom frequency of 123.00, and the call was made to taxi onto the active runway. One high-speed taxi was made, raising the tail off the runway to about 60MPH, then slowing down and returning to the taxiway. When the throttle was reduced the a/c felt very light. It was later confirmed with witnesses that the a/c had actually lifted off the runway slightly.
Engine gauges were monitored throughout this taxi period. Oil pressure and temperatures were within normal limits. The CHT was rising, but still in the green. It was felt that no further information was to be gained from additional taxi tests, so a takeoff was planned for the next run.
The radio call was made, and I back-taxied to take advantage of the full length of the 4700 foot runway. Acceleration proved normal. The engine RPM had been reaching only about 2000 on tests up to 60MPH. This was felt to be normal due to the high pitch of the propeller.
The a/c lifted off smoothly at about 65MPH IAS. I held the a/c level till the speed reached 8O MPH, then began a slow climb. Engine RPM rose to 2300, and IAS went up to I 100 MPH ROC was not observed at this time, although there is an ROC gauge in the a/c. The a/c felt very solid, with no signs of instability or out-of-trim condition, other than having to hold forward pressure on the control stick.
As per recommendations from other T- 18 pilots, the electric stabilator trim was set for a slight down pressure to aid in preventing overcontrolling in pitch on the first takeoff. After liftoff I was holding forward pressure on the stick to maintain level flight before climbing out. I trimmed the electric switch for down trim, and the pressure I had to hold forward increased, rather than decreased. Realizing that the trim switch was wired in reverse, I gave the switch full aft trim and was able to neutralize any stick pressure required.
First Flight Procedures
The objectives of the first flight were to establish a/c controlability, safe and normal engine operations, and any major or minor items that need correcting before any further flight testing.
The a/c climbed smoothly at I 1OOMPH IAS. Other than the aformentioned trim situation, nothing out of the ordinary was noted. A turn was made to crosswind, then very quickly to downwind, keeping a close pattern to facilitate returning to the runway should any emergencies arise.
The throttle was left in full-open position. On downwind the a/c accelerated to about 125-13OMPH IAS. Engine RPM read 2500. Oil temperature was at 180 degrees F, and the oil pressure at 60PSI, just within the green limits.
Three passes were made over the field at pattern altitude. The fourth and fifth passes were simulated approaches to landing. It was quickly discovered that the a/c is very slippery, that is, it was hard to slow down. On the sixth, and final, approach, the throttle was reduced at mid-field and the a/c was slowed to I 1OOMPH IAS by the time the turn to base leg was made. At this point the first notch of flaps was dropped. No additional flaps were used. The a/c was slowed to 90MPH IAS on base leg, then down to 85MPH on final, with engine RPM at about 1500. The approach was very smooth, with no tendency to divert direction or altitude. It actually felt like it were sliding down rails to the runway. Very stable, it flew much like a larger a/c.
Eighty-five MPH IAS was held to the numbers, then the throttle reduced to idle. The a/c flared very smoothly, with responsiveness, but not sensitivity, to stabilator input. With full-aft stick, the a/c touched down at the proper angle for all three wheels to contact the runway at the same time.
As the a/c rolled out straight and true, with only minor input to the rudder pedals, I made the audible comment to myself, "Well, that was a nonevent!", referring to the touchdown and rollout. I was rather surprised at how little effort it took to keep that a/c tracking straight.
No braking was used to slow down. I let the a/c roll till I had to add a little power to get to the turn off. I taxied back to the small gathering of observers, and parked in a tie-down spot before shutting down.
Author:  blueangel59 [ Mon Dec 04, 2017 10:00 pm ]
Mr. Bob Clayton's T-18 now resides @ North Las Vegas Airport (KVGT) across from Cubes Thorp Central!
Author:  Hagle347 [ Mon Dec 04, 2017 10:07 pm ]
It would seem that North Vegas is home to quite a few Thorps these days. I'd like to think it's a good thing to have Thorps in the air in large numbers.
T
Author:  Binder [ Sat Dec 09, 2017 11:17 am ]
150 mph on 5.5 with a 290?! That's insane. I see the prop measurements. Do you know what the take off roll is worth that prop? It's quite a bit faster than mine. I like the speed and fuel flow but also like my 800ft ground roll on take off.
Author:  James Grahn [ Sat Dec 09, 2017 8:24 pm ]
I'm going to fly it again tomorrow. I'll see if I can guess.
Author:  Binder [ Sun Dec 10, 2017 1:15 pm ]
Thanks, that would be helpful
On the iphone I use an app called "geomeasure". If you have a person in the plane with you they can start it when you are sitting then when you rotate they can hit stop and it will give you exact distance and put it on a map for you.
If not then I look for landmarks on the runway (displaced threshold, number of centerlines, etc) and note where I rotated. Then use that same app in the "manual measure" and you can zoom in on the map and calculate the distance between the 2 points. I've been doing that to get some info on my take off and landing rolls so I can plan for a short grass strip landing/take off here on the farm. Pretty fun stuff.
Estimation would be ok as well. I'm just curious. Hard to estimate prop difference since it's a higher pitch but also smaller diameter. I'm at a 68x68
Author:  James Grahn [ Sun Dec 10, 2017 8:09 pm ]
I didn't get airborne today. The new ADSB on the Tigress began pitching a fit, so I installed a new antenna instead.
Author:  Jeff J [ Sun Dec 10, 2017 8:46 pm ]
Bummer. I am glad I don’t fly in areas where ADSB will be required. I have had “in” for a year and it hasn’t proven useful at all to me. Neat yes but not useful.
Author:  James Grahn [ Mon Dec 11, 2017 9:06 pm ]
ADSB problems turned out to be a bad coax cable. She worked fine today. Was also able to fly in 818TR today. I did not have any accurate measuring device (did not download the app), but I'd guess we left the ground about 1200' down the runway. We are 2200' MSL, we were pretty close to gross weight. It was about 65 degrees with no wind.
Author:  blueangel59 [ Mon Dec 02, 2019 2:47 pm ]
This beautiful aircraft is back on the market based @ KVGT Jim McDougall 702-839-2933 $27,000 -- 137.7 total time on Airframe & Engine
