| Elevator trim position indicator http://thorp18.com/thorpforum/viewtopic.php?f=4&t=7833 |
| Author: | Ryan Allen [ Mon Sep 14, 2015 8:23 pm ] |
| Post subject: | Elevator trim position indicator |
I installed electric elevator trim ala Bill and Bob (grainger motor, limit switches). For those that have electric elevator trim installed, did yall also install a trim position indicator in your panel? If so, how did you wire it into your trim system? I find that I would like a position indicator, especially when preparing for takeoff. |
| Author: | fytrplt [ Mon Sep 14, 2015 9:38 pm ] |
| Post subject: | Re: Elevator trim position indicator |
Most of us have found that you don't need one due to the light controls of the Thorp. Take off trim can vary widely with cg such as fuel state and load. No one setting will be correct for all situations. I think you will find a trim indicator virtually useless. |
| Author: | Rich Brazell [ Mon Sep 14, 2015 10:05 pm ] |
Ryan : Go to Trim Systems on the main forum page and then hit horizontal trim system and there a whole pile of stuff to look at regarding trim position for T/O . RB
| Author: | Fly [ Tue Sep 15, 2015 12:12 am ] |
Hi Ryan, I've been working on a new panel for my Thorp and I think I've worked out a simple and light way to display trim position on my Dynon EFIS and EMS. I agree that trim position on the Thorp isn't absolutely necessary, it is however the only plane I have flown in the past 17,000 hours that didn't have a trim position indicator of some sort in the cockpit. I think it will be worth including. I purchased a Space Age Control string potentiometer P/N 173-0241. The potentiometer, mount, and wiring, will add about 2 oz to the airframe. Here's a specification sheet for the potentiometer I purchased. I found a vendor that had a new supply on eBay for $10 each. http://www.servocontrolsindia.com/wp-co ... r/170x.pdf Here's a photo of the potentiometer I'm using. The cable will attach to the aluminum arm that contacts the limit switches on the trim drive. ![]() Marshall |
| Author: | Ryan Allen [ Tue Sep 15, 2015 5:33 am ] |
well, I guess I should just keep flying and see if I still think i need the position indicator at next annual. Thanks for the feedback. |
| Author: | jrevens [ Tue Sep 15, 2015 1:36 pm ] |
Fly wrote: Hi Ryan, I've been working on a new panel for my Thorp and I think I've worked out a simple and light way to display trim position on my Dynon EFIS and EMS. I agree that trim position on the Thorp isn't absolutely necessary, it is however the only plane I have flown in the past 17,000 hours that didn't have a trim position indicator of some sort in the cockpit. I think it will be worth including. I purchased a Space Age Control string potentiometer P/N 173-0241. The potentiometer, mount, and wiring, will add about 2 oz to the airframe. Here's a specification sheet for the potentiometer I purchased. I found a vendor that had a new supply on eBay for $10 each. http://www.servocontrolsindia.com/wp-co ... r/170x.pdf Marshall I agree with Bob, & others who don't think a trim indicator is necessary on the Thorp. That being said, I think that is a really neat way to do it Marshall. Thanks for sharing it! |
| Author: | dickwolff [ Tue Sep 15, 2015 5:19 pm ] |
Agreed. I wasted a lot of time on an indicator because I thought "all airplanes have them." Just run trim full nose up and then run it back down a second or two and go flying. Focus on more important things. D |
| Author: | Tim Brown [ Wed Sep 16, 2015 4:28 pm ] |
I concur with Dick; I end up with near full aft trim after landing so I run it forward about 4-5 seconds or so on the roll if I'm going up again or taxiing back to the hangar, either way for me about 4-5 seconds forward trim from fully aft works 100% of the time... I have an indicator but its useless and I would have to get my head in the cockpit to use it even if it worked. |
| Author: | Rich Brazell [ Wed Sep 16, 2015 10:44 pm ] |
Taking off with a full tank of fuel w/or without a pax , w/or without baggage I use the same trim setting on my LED indicator . Landing with full flaps (90%+ of the time) I end up with approx. the same trim setting I had for T/O . I vary the trim setting for take off only slightly with less than a full tank . About 1/2 a bar on the indicator . The trim setting is one of the last items on my before take off check list to avoid the OH CRAP (or words to that effect) at rotation ! BOO YAH ! RB
| Author: | flyingfool [ Mon Oct 09, 2023 3:20 pm ] |
Interesting with the stern drive indicator. If the important thing to detect is whether the trim is working. Would a simple on/off light for energizing the trim circuit be used. Sure you would not know the position. But you could still determine that from full position and count in the opposite direction. If the light went on during those two directions, then you would have a reasonable assurance that the trim was moving, and might be a simpler installation. Or even two lights if you could get one light to turn on for nose up, and another light for nose down. I admit I know not even enough to be dangerous when it comes to anything electrical. |
| Author: | peterjaypriest [ Mon Oct 09, 2023 10:18 pm ] |
The problem with just indicator lights wired into the trim circuit, is that you will only know if the circuit is being energized. You still have no confirmation the trim motor is actually running. In my case, the circuit was fine- the trim motor relay was energized, and sending voltage to the trim motor. But the motor was open-circuit. By physically connecting a variable resistor (in my case, the boat stern drive trim sending unit) to the pitch mechanism, I'll see the needle move on the gauge, which affirms the pitch trim is actually changing. Lights for the trim motor might still be a good idea- they could warn of a stuck trim switch or relay, if nothing else. |
| Author: | pmandel [ Sun Oct 15, 2023 10:11 am ] |
From the peanut gallery -- electric trim, no indicator in N118BC. I use the full-up followed by 2-3 nose-down before takeoff method, and it works great. Until, to quote @peterjaypriest above, it didn't. Here's what happened: I used the aforementioned method, assuming all was well. Took off but had to use forward pressure on the stick to keep from pointing the nose to the sun, more and more as the aeroplane accelerated. I kept trimming nose-down using the switch, but no joy. Strange because before takeoff, I always run the switch and listen for motor noise, which was present, but nonetheless unable to get it off full nose-up trim. Landed, pulled it apart with my A&P/IA, found one of the roll pins in the universal joint had failed. So she spun round and round with no effect on the physical trim where you need it. Ergo, per discussion above, lights telling you that you are energizing the motor would have fooled me because I was energizing the motor just fine. Better lights (or more likely "light" (singular)) would be a full-up light, meaning the "full up" limit switch has been activated. Then the pre-takeoff check is: 1. Full nose-up trim via the switch -- confirm full nose-up light ON. 2. Trim down and count the seconds, roughly -- confirm full nose-up light goes OFF within "x" seconds. 3. Take off and FLY...or repeat 1. and 2. a time or two for confirmation, if desired...THEN fly. |
| Author: | fytrplt [ Sun Oct 15, 2023 8:29 pm ] |
Just remember, the neutral or slightly nose down position varies with each cg situation. There is no one perfect take off trim position. |
