| Bearing for jack screw http://thorp18.com/thorpforum/viewtopic.php?f=4&t=7207 |
| Author: | ljkrume [ Thu Jan 24, 2013 3:37 pm ] |
| Post subject: | Bearing for jack screw |
Anyone tried to located a source for the self-aligning bearing on the jack screw? I hope no one is using the standard type - it needs to move a little. Drawing #701 calls for Fafnir K55. 3/8" ID, 7/8" OD, 1/4" Wide. Mine has axial play which of course shows up on the tabs (not good). I've heard some put a nylon shim behind the head of the screw, but would rather get a new bearing. I'm workin hard at all the rest too. Thanks in advance... Les Krumel, Albuquerque |
| Author: | stug [ Thu Jan 24, 2013 3:54 pm ] |
| Post subject: | Re: Bearing for jack screw |
Les try Aircraft Spruce I think the equivalent bearing is KS SERIES BEARINGS MS27645-6A Part # KS6A |
| Author: | bjwest [ Thu Jan 24, 2013 8:15 pm ] |
Les I just got one from Aircraft Spruce. You still need a shim behind the new one, there is about .030 inch axial play in the new one. Brian |
| Author: | jrevens [ Fri Jan 25, 2013 2:41 pm ] |
Les, Shimming, usually with a thin disc cut from plastic, has been necessary "forever". A new bearing will not eliminate the small amount of axial play. |
| Author: | James Grahn [ Sat Jan 26, 2013 12:11 am ] |
I'm sure Mike has some as well Cubes |
| Author: | dickwolff [ Sun Jan 27, 2013 8:56 am ] |
I bought a couple from a guy in BC who had a bunch of a/c surplus inventory. That was three years ago. Not sure if he's still around. His company was Aero Dynamic Solutions, I think. Tony Jensen aerodyna@island.net 250-956-2233 I have a spare. PM me if interested. |
