It is currently Sat Aug 29, 2026 5:07 pm
PapaGolf
PostPosted: Wed Feb 07, 2024 12:51 am
As Bob Highley suggested in the FB group, I am finally starting a project thread here on .NET! I have been lurking this forum and the FB group for a while now but let me introduce myself. I'm Pete Geraci and I've been a mechanic for 25 years, starting in the Air Force, a few years at a GA flight school and then corporate jets for the last 18 where I've mostly specialized in avionics. I earned my private certificate in 2005 and have flown when I can although not nearly as much as I would like! That said, 2020 I was ready to start a father/sons project building an RV-14(boo I know!). Like many people, COVID changed a few plans and I decided that might have been a bad time for a major project. Talking with one of my friends at work, he told me the tale of a Thorp, how he came to own it, what his plans were, and how life events had taken his ability to really devote the time to it.
So, What started as helping a friend shed the cost of storing it, ended up with it occupying my garage for the last 2 years. As best as I can understand, This airframe was build by James Dewberry of Alabama and received its first CofA in 1972. According to the dataplate, it first flew with an O-290 and spent more time getting modified than flown. According to the airframe log it took nearly 21 years, 1993, to reach its first 40 hours! It then flew quite a bit for a while but was disassembled for storage in January of 2002 with 256 hours. The logbook is quiet for 11 years when suddenly it was fitted with a Lycoming O-360, went back to phase 1 for a few hours, and the last airframe logbook entry is the end of March 2012, when at 261.3 hours, it was returned to phase 2.
The owner at the time had trouble with ground handling and ran off the side of a taxi way (I'll go into my theory on that another day, no spoilers FB!). June of 2012, he removed the damaged Hartzell CS prop/governor, dialed the crank(.002), and installed a Sterba FP wooden propeller.
My friend traded his Cessna 152 for this, looking forward to the "Thorp Experience"! Unfortunately, a fuel leak developed in the custom built fiberglass fuel tank. He purchased the plans at that time with the intent of fabricating the fuel tank as drawn to install it and quickly discovered that the original builder had gone off the map with a custom tank, mounts, firewall supports, a set of modified Cessna rudder pedals and brake cylinders. The fiberglass tank was also smaller (I think 15 gallons), allowing for a full depth center avionics stack after the panel was relocated aft approximately 5 inches. So what started as going back to a plans built tank has tsunami'ed.
I was initially asked to evaluate it, see if it was even worth saving. The sad reality is, if the guys working for me weren't cheap, it would easily be beyond economical repair. For that fact, it would probably be easier and cheaper to buy the kit from Cubes and build! But, it landed in the lap of a nostalgic coot that has a knack for breathing new life into old stuff.
The tach, covered in dust sitting in a box of radios and gauges, reads 270.3 hours. The wings hang in racks from my garage ceiling, the tail feathers on the back wall. The engine found my homemade stand and the fuselage is casually hanging off of both ends of EAA 1000 inspired workbenches. A care package from Cubes showed up not so long ago with a new firewall and some misc. parts. So the question is, how good is an avionics guy at sheet metal!
PapaGolf
PostPosted: Wed Feb 07, 2024 1:18 am
The thread that got me started was things I found that were not in the drawings and I noticed were different from other T-18's out there. The first clue was the internal horizontal stabilizer balance weight. as drawn, is straight with the weight hanging in between the arms. Mine, has spacers where the weight should be, the weight hanging from the arms, and then the arms themselves are bent and reinforced. Looking at the current travel of the stab, the arms barely clear the upper skin leading me to believe this was modified to eliminate contact. The red markings on the angles are similar to others observed in the airframe so it would appear this was done at build.
The seat supports seem to be correctly located but the backs are extremely thin. The control sticks were bent and welded to move the grip approximately 4.5 inches aft of center as opposed to the straight sticks I've seen in most cockpit pictures. Shown is the removable copilots stick.
I also found shims nearly 3/8's thick that moved the wing aft. I haven't found any spacers for the aft spar fittings but according to some measurements I took yesterday, I would have to have them to mate the wing with the main spar shims installed.
Additionally, the instrument panel was moved approximately 4.5-5 inches aft which Bob Highley told me was a pretty common mod. This one however, had a full IFR stack with vacuum gyros and the most recent weighing showed 1363lbs @ 63.24. My theory is once a modern American and a sack of pilot stuff was thrown in the back that it may have created an aft CG condition. Locating the wing aft may have offset the flight characteristics a bit but I was curious how close I am to guessing an aft CG loading could make ground handling a little sporty. (I have no tailwheel time BTW so feel free to correct me)
Has anyone else seen anything like this or have any carnal knowledge of this airframe? Thanks again! -Pete
PostPosted: Wed Feb 07, 2024 11:09 am
There are 2 items of concern on the 'bob weight'. The weight itself should be sandwiched between the angle stock. AND the part should be straight - not 'adjusted'. Both point to the collar on the stab being installed at the wrong angle. I've seen that on another Thorp I was involved with on a much smaller scale . The result of this mod will not allow you to get the full and proper angle of up and down horizontal stab movement . That also negatively affects aircraft handing.
- With regards to the front spar shims....were the rear spars shimmed as well?
Keep posting and asking questions - We'll get it correct!
PostPosted: Wed Feb 07, 2024 12:03 pm
I think it’s worth saving!!
But I would return it to plans configuration. I’m not an engineer, but I can tell you that unintended consequences often happen with even minor mods. Those are not minor mods!
Terry is right, the 510 might have been installed at the wrong angle. Not sure how to fix that.
I would move the wing back to the normal position. With a fixed pitch prop, you should be right in the sweet spot of the CG.
PapaGolf
PostPosted: Wed Feb 07, 2024 6:11 pm
I'll have to check the angle of the 510 arm, it may be what it is. I'm changing the trim to electric so once I get to re mating the stab I'll check the throws to make sure I'm getting good deflection. Hopefully it was remedy for an Oops that worked out. re orienting the 510 doesnt look like an easy thing to do but I'll address that when I get there.
I haven't found any shims for the aft spar but I measured the wing and compared it to the fuse and there would have to be something there to take up the slack. Hopefully that doesn't mess with the flap slot alignment but thats a future me problem for now!
I'm definitely going to try and get this as close to the plans as I can. The firewall change came into play once I realized the original fuel tank supports were installed several inches outboard and the number of holes punched in it would probably divert the fire into the fuel tank! Another oddity was the angle that held the fire wall to the lower structural brace was on top of the brace instead of the bottom where the fuel tank mounts were solely supported by the firewall and not riveted to the brace. Thankfully I was able to unbolt the brace and flip it with out having to remove and re-rivet the angle on.
good news is initial fitting of the new one is going well! Image
PostPosted: Thu Feb 08, 2024 12:49 am
Awesome! You do quick work.
PostPosted: Thu Feb 08, 2024 10:17 am
A quick check of your stabilator and the placement of the 510-1 bracket may tell the tale. The 510 is to be installed 14 degrees 2 minutes slanted up from the horizontal axis of the stab. A not so uncommon mistake of the early builders was to install it at right angles to the stab. Many early builders were building ahead of John Thorp's final release of drawings. Several were being built in the Atlanta area and even had round fuselages. The fatal accident that resulted in the redesign of the horizontal tail was caused the bracket installation mistake and subsequent fix. The builder drilled out the rivets on 510-1 and correctly positioned it and redrilled the holes and re-riveted it. He essentially perforated the tube spar. A sharp pull up after a highspeed pass was all it took to fracture the spar. The spar doubler, redistributed bobweights, and the oh so important stainless steel straps on the tab were a result of this accident.
If you make your way to Sun 'n Fun this year, I would be glad to meet up with you and show you my finished plane and the one I have under construction. I am based in Lakeland Florida.
Rv3maker
PostPosted: Sat May 11, 2024 10:55 am
PapaGolf, how is it going? Any updates? Keep us posted!
I am going to start a project thread pretty soon myself . . . .let's keep each other in check!
Rob
Rob
RV-3 SN 45 (project)
RV-6A SN 24654 (flying)
KEWK
PapaGolf
PostPosted: Thu Jun 27, 2024 9:00 pm
RV3maker. Thanks for asking! Unfortunately my family and I were hit with a series of health issues that knocked down my ability to get the physical work done for a bit. Hopefully I’ll be able to pick up the rivet gun soon!
In the meantime just for an update, the vacuum system and original instrument panel have been donated to a local High Schools budding aviation program. Some shopping and horse trading has landed me with a 10” Dynon Skyview system with the engine monitor for the Lycoming that’s still awaiting overhaul. I also picked up an efis-d10a that will make a good standby instrument. It came with the autopilot servos, although I had no plans for an AP, they’re compatible with Skyview so I guess I’ll have an AP! A Stratus ES transponder will replace the King KT76 mode C unit to fit the ADS-B out requirement. I have a stratux unit I’ve used for ads-b in. I’m going to experiment and see if it will feed the Skyview. Worst case I’ll have the data on ForeFlight for now.
The only issue I have right now is what to do with the other stuff I have. I still have an ICom VHF radio, a Narco Mk12D with glide slope. And a KLN-89B IFR GPS. Oddly enough I’m considerings reusing them. I like the idea of having VOR/ILS and even though the Skyview has WAAS, the 89B is approach certified. I don’t have my instrument yet but I like the idea of being equipped in case I end up in the soup. I would eventually like to get a good navigator so I can fly a nav coupled approach but getting it flying and back through phase 1 is the priority.
Engine wise, the O-360 was prop struck, 300 beyond TBO, and hasn’t been run since 2012 as best I can tell. The Carb wasn’t drained so it needs an overhaul. The dual mag is obsolete and several hundred beyond its 500 hour. The ignition harness is shot as well. That said I’ve been considering going with an EFI/electronic ignition system. I’m not excited about flyefii or system32 though.
To that end, I’ve been bench testing a custom ECU with the goal of having a full sequential injection/ignition. The other two use a batch fire, wasted spark algorithm that leaves fuel sitting on the back of the intake valve and double fires every spark plug. The one that has an option for a redundant ecu apparently has a rather unnerving changeover if something happens. My sitting on the couch for 3 months design is based off the same FADEC that runs the Rolls Royce BR-710 engines on the G550s I take care of. Effectively two always on engine controls that take turns being in control monitored by a third that can vote one off the island if it starts acting stupid.
So that’s the latest! I’ve taken the downtime to do all of the brain work. Drawing schematics, acquiring parts, and rebuilding the typewriter written flight manual. It’s been a lot of work but since I can’t fly right now anyways, I might as well build!
I’ll keep an eye out for your project thread, always good to see what we’re all up to!
PapaGolf
PostPosted: Wed Sep 03, 2025 1:33 pm
Sometimes we get stuck in the mud! Its been a while since my last post but finally I have some movement. The O-360 engine that was "ready to run" was torn down over the last few months. I went to pull a cylinder to inspect the cam and found a cracked rocker lug, once the cylinder was out of the way, a chip on the very tip of the furthest aft cam lobe. This engine wasn't far from catastrophic failure. One of these days I'll get the parts boxed up and shipped off for overhaul. Hopefully the rest of the engine passes muster!
Continuing my "conformity" inspection revealed some more not to print type stuff. The Elevator push-pull tube has this odd angled end. Again, I wasn't there when this was all disassembled but I'll be curious to see how this fits, particularly with our previous discussion about the counterweight modification I found previously. I eyeballed the 510-1 bracket and it appears to be the correct angle. I'll have to drop a pic later but it appears to be half AD rivets and half something else with a thin hex on the exterior. Just as a ponderance, how do those rivets even get driven?!
The big find though(thanks Cubes for the FB feedback) was someone cut the bulkhead and deck behind the seats to open up the baggage compartment. They added some 1x1x3/16 angle behind the seats and one on the back wall of the baggage in an attempt to compensate but I don't see how this would translate any yaw force across the upper deck. I'll definitely have to restore this area and figure something else out.
On a good note, I finally got around to drilling all of the rivets out of the closeout into the tail. Aside from 50 years worth of dust collection, it seems in pretty good shape back there. There is an aft facing vent back there that I'm not sure what its purpose would be as there was no way for airflow to get from the cabin to the tail minus cutouts for the seatbelts. I may try to close this up with some ducting, seems like a good place for rats or snakes to hitch a ride...
Lastly! I have some mild oil canning going on on the sides of the fuselage. just forward of the stab. Some of the rivets need to be replaced so I was considering replacing all of the frame rivets pondering if I were to dimple and go back with countersunk rivets, would that take up some of the skin and reduce the canning?
PROGRESS!
PostPosted: Mon Sep 08, 2025 11:21 am
I guess on that angled bracket is that it was used to lower the tunnel between the seats. It would be enlightening to see that tunnel.
[ Time : 0.166s | 12 Queries | GZIP : On ]
