 Post subject: Project For Sale
PostPosted: Mon Oct 08, 2018 3:58 am
Very nice T 18 with light damage for sale. Lycon 0-360 dyno at 217 HP, Hartzell constant speed, both with less than 50 hours, Garmin G5, SL 30, Stratus Transponder W ADSB, Trutrack autopilot, Grand Rapids engine monitor system, New windshield, New Leather interior, Trusty wing with 2 additional 8 gal fillet tanks. Needs new tail wheel assembly, outer right wing repair, landing gear is bent. No prop strike. About 3K of parts needed and 150 hours of labor to make all repairs.
I am looking for offers and may sell engine and prop separate. Call(530) 320 6758 or send a P/M for photos. I go to bed early, so please no calls after 7:30 Pacific time. Phil
 Post subject: Re: Project For Sale
PostPosted: Sun Oct 14, 2018 7:00 am
I have received quite a few calls with the same questions, following is information to clear up those questions:
The airplane is on the West Coast Hangered near Sacramento Ca.
The plane has not been sitting for years, it was flying a little over a month ago.
The outer wing panels have been removed, I moved the plane using a trailer with a wide load permit.
The right outer wing panel needs to be reskinned and I would replace the rear spar in this outer panel.
The main landing gear A frame needs to be replaced.
The right outer main landing gear wheel half needs to be replaced.
There is some fiberglass repair on the right wing tip (a split where the original seem was)
Yes, the engine dyno at Lycon was 217 HP, and is a parallel valve engine.
Then prop did NOT hit and there was Not a sudden stop of the engine
I do have all of the log books and have the plane on the Ad Log paper log book system.
I am going to put a ad in Barnstormers later this week
Hope this helps, Phil
[ Time : 0.196s | 9 Queries | GZIP : On ]
