| Keep VOR Antenna? http://thorp18.com/thorpforum/viewtopic.php?f=36&t=8116 |
| Author: | jtwigg [ Wed Jul 19, 2017 9:00 am ] |
| Post subject: | Keep VOR Antenna? |
In you guys' opinions, is there a good reason to keep an installed VOR antenna these days? My Thorp T-18, N12055, has a VOR antenna on the top of the vertical stabilizer. I'm thinking about removing it and the associated RG-58 coax cable that runs up to the cockpit to save weight and drag. I'll be using a GPS tablet for now and will replace the steam gauge instruments with EFIS / GPS after a year or so. Heck, even the little Yaesu FTA-750 radios pick up VOR signals without the need for a VOR Antenna. I plan to fly VFR-only.
| Author: | James Grahn [ Wed Jul 19, 2017 11:12 am ] |
| Post subject: | Re: Keep VOR Antenna? |
Personal choice. I have one. But then again, my bird is full up IFR. Cubes |
| Author: | Rich Brazell [ Wed Jul 19, 2017 12:38 pm ] |
The VOR will go the way of the Omega , NDB and lighted airways . I use the iFLY 720 GPS and should that unit decide to make a new bed I have a backup iFLY 520 GPS (much smaller unit with built in battery) . I thought about getting a handheld with VOR capability , but why ? Day VFR , (2) GPS and for the worst case nightmare a bound book of paper sectionals and a #2 pencil . RB
| Author: | Fraser MacPhee [ Wed Jul 19, 2017 1:43 pm ] |
1. If you ever want to fly IFR, keep the VOR 2. If you are near some restricted areas and decide you will fly X-country when the zoomies play weebeejammin the GPS (they do it out here on occasion for an hour or two), you might appreciate the VOR. For what it's worth, I decomm'd my VOR off the KX-155 a couple of years ago - sold the indicator for a Morton's steak dinner for two.....wish I didn't. |
| Author: | jtwigg [ Thu May 31, 2018 2:25 am ] |
Hi everyone, just a quick update to let you know that I ditched the VOR coax cable running thru the rear fuselage. I decided I didn't want the weight and it was run thru holes in the bulkheads that I could put to better use without drilling new holes. Thanks for all your suggestions! |
| Author: | SHIPCHIEF [ Thu May 31, 2018 11:36 am ] |
For what it's worth; I removed the VOR antenna from 'Feisty' because it just about put my eye out. It was at that perfect height on top of the vertical stab. I might try an Archer #1 wingtip antenna if I add a VOR in the future... https://www.aircraftspruce.com/catalog/ ... enna-1.php |
| Author: | Rich Brazell [ Thu May 31, 2018 12:13 pm ] |
Didn't your mother tell you that could put an eye out ! RB
| Author: | SHIPCHIEF [ Thu May 31, 2018 12:18 pm ] |
RB; Well, maybe. Wasn't that "A Christmas Story" and something about a BB gun? https://www.youtube.com/watch?v=mrAwb9ptu9U |
| Author: | Rich Brazell [ Thu May 31, 2018 1:50 pm ] |
Could be ? I got a 50 cal for x-mas . RB
| Author: | Ryan Allen [ Fri Jun 01, 2018 8:41 pm ] |
SHIPCHIEF wrote: For what it's worth; I removed the VOR antenna from 'Feisty' because it just about put my eye out. It was at that perfect height on top of the vertical stab. I might try an Archer #1 wingtip antenna if I add a VOR in the future... https://www.aircraftspruce.com/catalog/ ... enna-1.php I bought foam clown noses from hobby lobby and stuck them on the end of the antennas because I too was worried about poking my eye out. I forget about them alot, so there are clown noses all over our airport! |
