| C-FVBG aka N886Y aka MLM http://thorp18.com/thorpforum/viewtopic.php?f=36&t=7521 |
Page 1 of 5 |
| Author: | bfinney [ Tue Feb 11, 2014 12:33 am ] |
| Post subject: | Re: C-FVBG aka N886Y aka MLM |
Dick, I like your tip for installing Adel clamps. One question, how did you sneek the kitchen implement out to the work shop with out "She Who Must Be Obeyed" seeing????? Inquiring minds want to know. |
| Author: | dickwolff [ Tue Feb 11, 2014 6:09 am ] |
That's one advantage of being a born-again bachelor. |
| Author: | Fraser MacPhee [ Tue Feb 11, 2014 10:22 am ] |
Love the new grounding busses - how do you remove that fuel cap? |
| Author: | dickwolff [ Tue Feb 11, 2014 11:31 am ] |
Indeed... there is not alot of room between the cap and the edge of the doubler, but a Cirque du Soleil performer would have no trouble with it as long as he knows the trick. I'm going to braise a ridge-handle across the top. |
| Author: | mattst18 [ Tue Feb 11, 2014 12:13 pm ] |
Looks great Dick. Hope to see it and you at KY Dam this fall! |
| Author: | jrevens [ Tue Feb 11, 2014 12:40 pm ] |
dickwolff wrote: Indeed... there is not alot of room between the cap and the edge of the doubler, but a Cirque du Soleil performer would have no trouble with it as long as he knows the trick. ... snip... A child of 3 could do it... with 30 years experience. Looks good, Dick! |
| Author: | Pacer 20 [ Tue Feb 11, 2014 9:23 pm ] |
He Dick! Do you need more help Keep going, one this yellow bird flight again! |
| Author: | dickwolff [ Wed Feb 12, 2014 6:47 am ] |
Thanks, Thierry, but I'm beyond help. |
| Author: | Ryan Allen [ Thu Feb 13, 2014 6:53 pm ] |
Dick can you tell me the name of the flap actuator you have and where you bought it? Ryan |
| Author: | Rich Brazell [ Thu Feb 13, 2014 7:22 pm ] |
I'll raise you $20 a child of 2 could do it with 20 years experience . Call.... RB
| Author: | dickwolff [ Thu Feb 13, 2014 8:48 pm ] |
The actuator is a Fergilli, 3" stoke. Several guys have used them in their T18's. There is one reported failure. I'm not too worried about it. http://firgelliauto.com/product_info.ph ... ucts_id=34 |
| Author: | Fraser MacPhee [ Fri Feb 14, 2014 4:30 pm ] |
I'll check when I get home, but I'm pretty sure the actuator I installed last year has a 4 inch stroke....... ?........is that why you're still a batchelor..?......TOOT! >:D
| Author: | leewwalton [ Fri Feb 14, 2014 4:58 pm ] |
Dick's correct .. you want the 2" stroke actuator. The Original 40 deg flaps is right under 3 inches, 2 inches is puts it at the second notch which is where we want to be. ((2 * 3.14 * 2.12)/360) * 80 = 2.96 Where 2.12 is the length of the original flap handles horn ... guess it does pay to listen in math class
| Author: | dickwolff [ Wed Feb 19, 2014 11:43 am ] |
That jives with what I found. I had to move the limit switch to limit the stroke... 2.25" according to my notes, but 2" would have been fine. No fuss, no muss. D |
| Page 1 of 5 | All times are UTC - 6 hours [ DST ] |
