OK so the reason for the fuel filler being on the left remains a mystery but I have managed to do some work on the tail this week and of course that means new questions. Also attached is a picture of how I beefed up the fitting for the tail landing gear attachment. I have tried to keep weight low and not make it too much bigger but hopefully it will do the job. As has been reported by others extending the fitting out to the lover longeron and attaching it with a couple of screws should make it much tougher. I also wanted to check how, if at all, the WL42 longerons are joggled to fit the stabilator hinge brackets? I can't find a drawing showing enough detail to make it clear to me what I do in this area. However unless I do something the skin won't sit flush just forward of the fitting. Also I am not sure I have interpreted the drawing changes on the 576 drawing correctly. John Thorp made an alteration to the 576 bulkhead as well as the 582 doubler that carries the trim jackscrew bearing however the 576 drawing was never updated with all the detail. So my question is should the heads of the 4 screws that hold the trim jack screw bearing come through the 576 frame? You can see in my photo that I haven't got them doing that, but as I went to assemble them it sort of made sense. Any suggestions?
Attachments: |
_________________ Stug
