It is currently Fri Oct 23, 2026 5:28 am
Post new topic Reply to topic  [ 252 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 17  Next
 Post subject: Re: C-FPVE
PostPosted: Sun Sep 22, 2013 3:29 pm
I have a drawing by Lou Sunderland that shows the three bolts.
PostPosted: Sun Sep 22, 2013 7:36 pm
The two internal weights came with my project and I "assume" they came from Phil Tucker or Ken Knowles . I have 2 sets of S-18 plans and could not find out how to attach the "fishing weights ?" So I did the CS NAS screws and to this day they are still in place and I have not caught any fish ! 8)
PostPosted: Mon Sep 23, 2013 5:07 am
The drawing is 502 an dated 15 Nov 84 and was drawn by LS. It shows 3 AN507R-1032 screws holding the weight. I have been told this internal weight was approved by JT.
I have found when the plans set were sold to the builder, not all received the same drawings in their set. As a note you will note in the bottom left corner it will refer to the next drawing. Several times this drawing would be omitted as not needed. I I would call Phil and have him send it to me just for reference.
Pacer 20
PostPosted: Wed Sep 25, 2013 6:55 pm
Trim tab is started!!!
I found small aluminium spare to build these parts.
The small rib ready to install.
First is completed...
And with the ''right click'' I do the copy and paste.
Et voila 2 pieces identiques ;)
Next step is cutting the small triangular aluminium plate 1/4 or 3/8 thick and drill the two hole for the AN3 bolt. I see the specification on the plan but for this moment I dont remember...
I take a closer look tomorrow morning.
Thierry
French Canadian T-18
C-FPVE #091
PostPosted: Wed Sep 25, 2013 7:08 pm
.016 or .020?
Pacer 20
PostPosted: Wed Sep 25, 2013 8:13 pm
I made both trim skin with 2024T3 0,025.
Under 0,020 is looks like cigaret paper...
Thierry
C-FPVE #091
PostPosted: Wed Sep 25, 2013 8:17 pm
Well done .. The .016 gets a bit serarnwrap ish
PostPosted: Wed Sep 25, 2013 8:20 pm
To clarify most older thorps with any .016 skins suffer hangar rash ... I limit .016 to templates or interior usage.
Pacer 20
PostPosted: Wed Sep 25, 2013 8:40 pm
Absolutely true!!!
Under 0.020 when the skin is corrugated it's more stronger.
My 2 cents ;)
Thierry
C-FPVE #091
PostPosted: Thu Sep 26, 2013 4:32 pm
I made mine from .016 as per the prints, & I think they look fine. They've held up well for 23 years, & pretty much look the same as when I built them. My personal opinion is that you should be very careful about making any structural changes to critical parts of the stabilator assembly especially. I believe it's likely that thicker skins are PROBABLY just fine... stronger & heavier is all. But keep in mind that the testing done by John Thorp after the flutter issues pointed out how important seemingly minor changes were, and how they had a drastic effect on flutter vulnerability.
Pacer 20
PostPosted: Wed Oct 02, 2013 8:34 pm
Thanks Jrevens for the inquiry about the extra weight. I want to weight my new trim in 0.025 versus my original in 0,016. I keep you posted about the result.
Trim ready to riveting and the SS starp was installed inside.
When I installed the stab on the fuselage for the first time I sing the 2001 Space Odyssey sound track, you know with the big drum sound!!!!!
I'm so happy to see the complete tail section!!!
I finished to cleaned all the welding areas. Now I have a new old canopy rail. I have to make a small jig to fix all the frame tubing before the last welding process.
I found the canopy rail drawing and I start the design in the SS strip.
Some trimming to do, but I'm pretty sure the second rail need no adjustment.
Et....Voila....
Thierry
C-FPVE #091
PostPosted: Thu Oct 03, 2013 4:45 am
Thierry, Mike Archer sells front and rear canopy rails for cheap. ~$16 ea if I remember right.
Pacer 20
PostPosted: Thu Oct 03, 2013 5:47 am
I call Mike Archer and he has no parts in stock. I take almost an hour to design, cut and bend the two rails. Today I do the rear, I bend a long part and I cut the piece in two!
Thierry
C-FPVE #091
PostPosted: Thu Oct 03, 2013 12:29 pm
Wow Thierry.
It looks like you can build parts faster than you can buy them!
The S2 looks great.
Based on my own experience, I worry about folks getting into small planes because they are quick and landings can be a bit intimidating if the stall speed is high.
I'd say you have that training well covered for the T-18, having flown the S2!!
PostPosted: Thu Dec 12, 2013 1:48 pm
Thierry, you are too quiet! We need a Christmas update to rekindle the motivational fires.
[ Time : 0.266s | 10 Queries | GZIP : On ]
