It is currently Tue Feb 03, 2026 5:24 pm
Post new topic Reply to topic  [ 268 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18
PostPosted: Sun Nov 02, 2025 2:58 pm
Take a look at edge distance for the shortest line from the pin hole to any edge. If you can shave off the fitting and not decrease that distance, you are good.
PostPosted: Sun Nov 02, 2025 7:34 pm
I hammered out a very slight blister in the wing gap cover to get around the protruding angle. Its actually so slight, its almost imperceptible. I was surprised it only took about 3-4 minutes to hammer out the little bulge in the gap cover. If it was much more, I would definitely check on edge distance for trimming. I appreciate the input. It helps.
 Post subject: Wing Tie down photos
PostPosted: Thu Nov 13, 2025 1:26 pm
Where and how have you attached you wing tie down rings? Pictures would be very helpful.
PostPosted: Thu Nov 13, 2025 2:29 pm
My tie downs are attached to the end of the main spar of the outer wing panel.
PostPosted: Thu Nov 13, 2025 7:44 pm
thanks Bruce. I hadnt thought about the outer wing.
PostPosted: Tue Dec 30, 2025 4:07 pm
The aileron trim I have in my flying airplane is a Ray Allen (RAC) trim servo and is now priced at $550. I was hoping to find something a little less expensive for my project airplane. Anyone have any suggestions?
PS Bruce, I copied you and installed my tie down rings like you suggested.
PostPosted: Sat Jan 10, 2026 4:32 pm
Was thinking about using these countersunk washers under the screw heads on my fiberglass wingtips, but do these countersunk washers do anything to help protect the integrity of the fiberglass or are they just for looks?
PostPosted: Sun Jan 11, 2026 2:19 am
Ryan,
I have the countersunk washers on my wingtips, they help spread the load over a larger area of the fiberglass and help keep the screws from pulling through. I had several screws pull through before I installed the washers.
PostPosted: Sun Jan 11, 2026 8:27 am
got it. thanks Bruce.
PostPosted: Sun Feb 01, 2026 2:24 pm
Here is my issue. I cant see the best method to attach the rear nav light to the housing. Any suggestions?
isyncro
PostPosted: Sun Feb 01, 2026 5:02 pm
May be this may help? https://www.kitplanes.com/adding-a-taillight-to-a-completed-rudder/
PostPosted: Sun Feb 01, 2026 5:12 pm
Interesting, thanks! He used friction to hold the light inside the housing. Unfortunately, I dont think that will work in my case.
PostPosted: Mon Feb 02, 2026 1:52 pm
I also used the counter sunk stainless steel washers on my fiberglass tips. No problem in over 15 years !
O0 RB
NX115RX
2019
Users browsing this forum: isyncro and 2 guests
[ Time : 0.132s | 10 Queries | GZIP : On ]
