It is currently Mon Nov 23, 2026 10:02 pm
Post new topic Reply to topic  [ 271 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 19  Next
PostPosted: Sun Sep 09, 2018 5:37 pm
James Grahn wrote:
FWIW, I have S18 cables in stock as well. Jeff, they should be exactly 5 inches longer than the T.
I ordered rudder cables from you and installed them in my T-18... maybe you sold me T-18 rudder cables. It could be that something is just that different with my airplane. I don’t believe the T drawings specify a length for the rudder cables. I know my top and bottom rudder bushings are 2 different sizes.
PostPosted: Sun Sep 09, 2018 9:54 pm
That is correct. It doesn't. At least not directly. The top and bottom rudder Bushings should be the same size. Same as flaps as well. Drawing 581.
PostPosted: Mon Sep 10, 2018 8:08 am
One nice thing about homebuilt aircraft is that the drawings don't have to be followed verbatim. The down side of that is replacement parts per drawing don't always fit and I had to learn to be a little more cautious (measure first) when ordering parts.
 Post subject: Tunnel Question
PostPosted: Tue Jan 01, 2019 1:56 pm
I am confused. Please look at the photo of the tunnel and tunnel plans. The plans show an angle where my finger is pointing. My tunnel does not have this angle (in the background of the photo). I cant find the drawing that shows the "seat supports" on my tunnel. I am beginning to believe the 505 tunnel drawing you see in my photo has been superseded with a newer edition. You comments are appreciated.
File comment: Tunnel
PostPosted: Tue Jan 01, 2019 6:08 pm
I believe the seat installation was revised at some point. My aircraft has the angle in question but not the drawings. I don't have the standard Thorp seat installation. My drawing -505 has some indications that the angle was removed, drawing -855, seat installation, has the rivet locations indicated but not the angle. The drawings that you need are -855 installation, 852, 853, 854, 856 and 857.
My installation has a T section supporting a Cessna seat rail for a 150 seat.
Not the best photos but I think you get the idea.
File comment: Angle just visible under seat rail on the right.
File comment: Navworx ADS-B under pass seat
PostPosted: Tue Jan 01, 2019 6:38 pm
Dang Bruce, I love those seat rails. I often wondered if anyone had used those. Thanks for the tips.
 Post subject: Canopy Install Question
PostPosted: Mon Jul 01, 2019 5:59 pm
Is everyone using rivnuts to install their canopy or some other method? If so, how do you make the keyed notch in the canopy frame for the rivnut to bite?
PostPosted: Mon Jul 01, 2019 6:13 pm
I used the knerled kind They bite with out the notch. Fastenal.
PostPosted: Mon Jul 01, 2019 7:59 pm
Hi Ryan,
With "keyed" Rivnuts, I used a small, round "tool & die maker" file to make the little notch in the holes.
PostPosted: Wed Jul 03, 2019 6:41 am
Thanks for the guidance on the rivnuts. I drilled my canopy last night. I haven't drilled the canopy to oversized holes yet, but everything went great last night. I was worried about cracking the canopy the whole time. Its my biggest mental hurdle of this whole project.
File comment: Canopy
PostPosted: Wed Jul 03, 2019 2:38 pm
Well Done!
PostPosted: Mon Sep 30, 2019 7:11 pm
I have messed up 4 dang trim strips. The holes keep moving on me. I install the trim strip, mark it, drill it, mess it up by misdrilling holes in a few wrong spots, remove it, drill holes in the new trim strip using the old trim strip, install new trim strip, then I have other holes in the wrong spot! Dang it. I guess its trial and error, but if anybody has a trick to aligning the holes in the canopy with the trim strip, I would be all ears.
PostPosted: Mon Sep 30, 2019 9:10 pm
Cut trim strip over sized then use offset method to locate holes. Then trim strip to size.
PostPosted: Fri Oct 04, 2019 2:49 pm
well, bob, I did what you said it the trim strip is installed in about 20 minutes. sheesh, I cant believe it didn't strike me to do that in the first place.....
PostPosted: Sat Oct 05, 2019 7:18 pm
Great!
[ Time : 0.473s | 13 Queries | GZIP : On ]
