| Propeller Wallow Woes http://thorp18.com/thorpforum/viewtopic.php?f=35&t=8770 |
| Author: | peterjaypriest [ Fri Mar 17, 2023 10:41 pm ] |
| Post subject: | Propeller Wallow Woes |
Hello everyone... I've been spending the winter making some small improvements (I hope!) to my T18. New backup / aux alternator (Monkworkz,) slightly bigger battery, etc. In my recent avionics retrofit, I had a net shed of 27+ lbs. So, adding back a bit of weight for some electrical redundancy and capacity is acceptable, in my mind. The Monkworkz generator is like, 2.7 lbs including the external regulator. 30 amps! I pulled the prop spinner because there was a very slight resonance or rattle when it was tapped by hand. I thought I'd find the front bulkhead was loose or something. Instead, I found there was no front bulkhead (yikes!) and even worse, some of the spinner mounting holes were wallowed out, such that the screws were doing nothing in those locations. Ugh! Cubes is going to send a forward bulkhead / plate, so that will address one issue. But now this spinner needs the wallowed holes welded up and re-drilled. I found a shop that can do that, to the tune of several hundred bucks. That's fine, and I'll move in that direction. Unless... Any chance anyone has a ready-to-bolt on spinner the fits an IO360 and Hartzell extended hub c/s prop? I'd rather not go through the process of a new, blank spinner! This is the eddy current AD prop. Id be open to a B hub / prop if one turns up at a reasonable price. Otherwise, I'll continue with the inspections. (Are those required for Experimental applications?) Any thoughts? Peter |
| Author: | Ryan Allen [ Sat Mar 18, 2023 7:02 am ] |
| Post subject: | Re: Propeller Wallow Woes |
I am of no help to you, but i understand not wanting to start the spinner from a blank. I goofed up my spinner trying to drill the holes in the correct spots for the bulkheads and had to reorder a new spinner. Ouch! On a separate note, I wonder if you will be able to notice any improved flight characteristics after shedding 27 pounds? |
| Author: | peterjaypriest [ Sat Mar 18, 2023 10:52 am ] |
I can't say I noticed much change in performance. It's like 5 or 6 gallons of gas, in terms of weight. Noticeable? I guess, if you're really looking. This airplane already has fantastic performance. But knowing it's lighter makes me happy! At the time, I knew it was lighter, but didn't really know how much lighter. Since then, I've weighed what was removed, vs what was installed. I really need to get it on scales, and do a formal W&B. But now this dang spinner! Ugh! I guess I can still fly it, without spinner (Cubes, et al suggest that's not a problem.) But the looks! I plan to polish this (currently painted) spinner when it comes back from the welding repair shop. I love the look of a good-fitting polished spinner, like those I see elsewhere on this forum! |
| Author: | fytrplt [ Sat Apr 29, 2023 7:02 pm ] |
Call Hartzell and ask them what the actual degree of rotation is. |
| Author: | Ryan Allen [ Sun Apr 30, 2023 7:56 am ] |
while your talking to them, ask them if they have a spinner cutout template. There maybe one on their website available for download. |
| Author: | James Grahn [ Mon May 01, 2023 12:19 am ] |
Yes you can twist it. A better way to do that is to āCā clamp two 2/4ās on each side. Do not do it over the decal. Then you can rotate the blades. The return spring is very strong.. it will take about 2ā of board to get enough leverage. Cubes |
| Author: | Ryan Allen [ Wed May 03, 2023 6:52 am ] |
did you unplug any fittings to do that, or just brute force twist it? Just curious in case I ever need to use this technique. |
| Author: | peterjaypriest [ Wed May 03, 2023 9:41 am ] |
Just brute force. It's not too hard... |
