| Surefly Ignition http://thorp18.com/thorpforum/viewtopic.php?f=35&t=8382 |
| Author: | Jim Mantyla [ Wed Jun 19, 2019 8:56 am ] |
| Post subject: | Surefly Ignition |
Guys, I was wondering if anyone has tried the Surefly ignition system in their Thorp? I have an IO-320-D1A with the Hartzell C/S prop and will need to do the Slick, 500 hour check soon. The Surefly web info looks good but so do all the others. I like the fact that it is basically a plug and play system because I don't have real estate on my firewall for control boxes. Also the fact that it is an STC'd system helps with the confidence factor. Any feedback would be appreciated. regards, Jim |
| Author: | leewwalton [ Wed Jun 19, 2019 1:02 pm ] |
| Post subject: | Re: Surefly Ignition |
I have one in my Thorp .. same setup as you Jim. IO-320/CS prop. Jason Hutchison is the head of the company and a friend. I was one of the first adopters ... never had so much as a hint of a problem. Lee |
| Author: | James Grahn [ Wed Jun 19, 2019 7:28 pm ] |
Just a thought. I have slicks as well. I have the old style with metal gears. I’m over 1300 hours on them without messing with them. To me, if my mag timing doesn’t move a single degree in 21 years, I’m not touching them. Cubes |
| Author: | Jim Mantyla [ Thu Jun 20, 2019 8:46 am ] |
Lee, Do you have your Surefly set up for the advanced mode where it will alter the timing up to 38 degrees? If so do you see highter CHT's? Regards, Jim |
| Author: | leewwalton [ Thu Jun 20, 2019 10:59 am ] |
Jim, No mine is set up standard, I may chose to put it in advanced mode at some time though, I’m going to talk to Jason about that in a few weeks. |
