It is currently Sun Nov 08, 2026 11:30 am
Thorp Aircraft
PostPosted: Mon May 12, 2025 11:16 am
Does anyone have in there 'stuff' a good type 1 dynafocal mount for a Thorp they would like to sell. I am asking for someone else. I will build him one if no one else has one available.
Alex Pearson
Thorp Aircraft
210-365-3374
Alex Pearson
Thorp Aircraft
alex@thorpaircraft.com
(210) 365-3374
PostPosted: Wed May 14, 2025 8:19 am
I have a dynamical mount that was used with an O-320 and was changed out when an IO-320 was installed. Not sure what a type 1 is.
PostPosted: Wed May 14, 2025 12:47 pm
The one you swapped out for the IO-320 is the Type 1. You most likely have a type 2 available.
Thorp Aircraft
PostPosted: Sat May 17, 2025 8:57 am
Dynofocal Type 1 mounts are far more common than Dynofocal Type 2 mounts for Lycoming engines. The difference lays in the angle of the engine mount. On a Type 1 the angle is 30 degrees and on a Type 2 it is 180 degrees. The mount type is determined by the Lycoming engine case mount points. Most single engine applications for Lycoming engines (except for the early models) are Type 1. Lycoming engines made for a twin like a Twin Comanche used the Type 2.
Much older Lycoming designs like with the O-235 and O-290 as well as very early O-320 and O-360 used a Conical mount.
What is the model number of the engine your engine mount was attached to?
Alex Pearson
Thorp Aircraft
(210) 365-3374
PostPosted: Sat May 17, 2025 11:19 am
Good recap except it should read “18 degrees “ vs 180.
PostPosted: Sat May 17, 2025 1:20 pm
Alex
The previous engine was a O-320-E3D . I will take a picture of the mount tomorrow when I am at the hangar.
Regards,
PostPosted: Sat May 17, 2025 2:52 pm
That is a type1
Thorp Aircraft
PostPosted: Sun May 18, 2025 8:59 am
Oops. Thanks Cubes. Yes, Type 2 is 18 degrees. I cannot find a place to edit my original post.
Alex Pearson
Thorp Aircraft
(210) 365-3374
PostPosted: Sun May 18, 2025 11:56 am
Alex,
I was out to the hangar and have uploaded a picture of the mount. it is a bit dusty.
regards,
[ Time : 0.285s | 13 Queries | GZIP : On ]
