| Air Filter Assy http://thorp18.com/thorpforum/viewtopic.php?f=35&t=8251 |
| Author: | Unclerap [ Tue Jul 24, 2018 3:11 pm ] |
| Post subject: | Air Filter Assy |
My T18 has a plastic air filter holder, from my research it is a Matney. It's broken and I want to replace it with a Brackett. It appears the Matney is dimensionally similar to the BA 4210 used on Grummans. Anybody have a suggestion, guidance, etc? thanks Rap |
| Author: | Jeff J [ Wed Jul 25, 2018 8:01 am ] |
| Post subject: | Re: Air Filter Assy |
Mine has a BA-4106 if that helps.
| Author: | Binder [ Wed Jul 25, 2018 12:56 pm ] |
I'm going to jump in here to ask questions as well. Jeff, what intake assembly do you have? I have a round car based intake and it's not filtering well. I want to change it to something nice and new like what everyone else is using. I will have a post for it. |
| Author: | Jeff J [ Wed Jul 25, 2018 5:44 pm ] |
I am not 100% sure because I am not where I can check the receipts included in the aircraft file but I think it is this one: http://www.aircraftspruce.com/catalog/e ... ckkey=3787 I was thinking that I would like to change. There is no seal between my cowl and the air filter. |
| Author: | Unclerap [ Wed Jul 25, 2018 5:50 pm ] |
Jeff, thanks. Brackett 4210 and 4106 appear to be identical dimensions. Don't know the diff. Still researching. |
| Author: | Binder [ Thu Jul 26, 2018 7:49 pm ] |
Jeff J wrote: I am not 100% sure because I am not where I can check the receipts included in the aircraft file but I think it is this one: http://www.aircraftspruce.com/catalog/e ... ckkey=3787 I was thinking that I would like to change. There is no seal between my cowl and the air filter. Thanks for the link, that looks perfect! That's one thing I was thinking would cause a problem. Pressurized air is getting forced into my lower cowl thus causing less Delta differential for my cylinders. Mine has a gap around the intake and I was wanting to seal it up because I think the ram air is reducing my cooling to the cylinders. This also has a much better carb heat portion. I'll have to find a way to measure my cowl distance and then a way to seal it to the lower cowl to keep air from entering my lower cowl. My other thought was to run a duct from the back of my baffling like david read did in order to completely remove the scoop and thus reduce drag on this little 290 powered ship! |
| Author: | Jeff J [ Sun Jul 29, 2018 8:46 am ] |
My gap is pretty small so it may not be worth the effort to seal up. I would hate to change it just to have the engine and/or accessories start hitting the cowl again. My setup won’t support it but somewhere in these web pages are pictures of a setup using wetsuit material to connect the cowl to the airbox that I thought would work well. David’s setup should work good too. I don’t think I have seen pictures of it and I never made it down to meet him. |
| Author: | Bill Williams [ Sun Jul 29, 2018 12:00 pm ] |
Don't remember the name ,but the race car folks use a rubber round tube molded to a thin channel that slips over the edge of aluminum |
| Author: | Binder [ Mon Jul 30, 2018 5:52 pm ] |
Bill Williams wrote: Don't remember the name ,but the race car folks use a rubber round tube molded to a thin channel that slips over the edge of aluminum I might have to fiberglass in a round section and just hook scat tubing to it |
| Author: | Unclerap [ Sat Aug 04, 2018 2:38 pm ] |
Closing the loop to my question: The Brackett 4210 is dimensionally identical to the Matney. Fits perfectly. Rap |
