| Engine Chuggle http://thorp18.com/thorpforum/viewtopic.php?f=35&t=8170 |
| Author: | Rich Brazell [ Sun Nov 12, 2017 3:24 pm ] |
| Post subject: | Re: Engine Chuggle |
As the little man on Laugh In use to say..."Very Interesting!" There is a follow up Lycoming Service Instruction 1485A which might prove interesting (or Very Interesting) having to do with "new and improved" valve guide material shipped from Lycoming . If you have the new guides it is no longer necessary to complete the mandatory 400 hour inspection in the latest revision of SB No. 388 . It is "recommended" that the inspection from SB 388 be completed at 1000 hours or 1/2 way to TBO . New valve guide material was introduced in 1996 and since March 1998 all engines , cylinder kits and spare valve guides contain the new material . RB
| Author: | fytrplt [ Sun Nov 12, 2017 4:56 pm ] |
This is very true, My good Rich. ...However, my engine man, Herman, says the issue was/is not completely fixed by the introduction of the new and improved guides. I have also been advised that MMO (Marvel Mystery Oil) goes a long way to keep things running smooth. When queried a few years back, a noted Lycoming rep said, "It can't hurt." |
| Author: | james peran [ Sun Nov 12, 2017 5:42 pm ] |
We used synthetic based oil . had no problems . The 98 oct mogas has cleaning agent it keeps your valve and engine components clean i use periodically J.P.. |
| Author: | Jeff J [ Mon Nov 13, 2017 6:06 pm ] |
Where do you get 98 octane? I think 92 is the highest rating I have seen in mogas. |
| Author: | Rich Brazell [ Mon Nov 13, 2017 7:43 pm ] |
MMO ? I'll try some on my Cobb salad ! RB
| Author: | Binder [ Mon Nov 13, 2017 9:51 pm ] |
Jeff J wrote: Where do you get 98 octane? I think 92 is the highest rating I have seen in mogas. Every country but United States.
| Author: | DaveDABQ [ Tue Nov 14, 2017 11:19 am ] |
You know that MMO is now owned by the Turtle Wax company, right?? I recall "hearing" that an NTSB report/analysis of MMO found constituents included mineral oil, Stoddard solvent, and lard!! I'd buy some if "Hidden Valley" owned them. (See Cobb salad reference above) |
| Author: | Rich Brazell [ Tue Nov 14, 2017 1:57 pm ] |
Hummmmmm...lard ! Homer like lard ! RB
